G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I am having problems with the sound on my Dimension 3000 P4 3.0 gig (HT
enabled) 500meg ram, still running xp home
I have the original 70 gig hard drive as the master and a 120 gig drive as
the slave on the same ide cable.
I also have a DVD writer on the secondary IDE as the master.
These make up a C and a D drive, with the DVD as the E Drive.
I have managed to fault the problem down to disk activity, using the
performance monitor.
If I am playing a sound file in any of my players, on say the C drive and
any activity occurs on the D drive there is significant break up on the
audio. If this access is say a large video file the break up last for around
10 seconds.
Both hard drives check out 100% with chkdisk and are not fragmented.
I have also run a program called HD Tune to test the hard drives and these
are reporting ok.
(Testing the drive with a mp3 playing on the other causes the same
distortion)
However the Transfer rate of the slave drive is only 2.2 MB/sec whilst the
master is reporting 25.0 MB/sec.
This would look to me like the problem.
The device manager is reporting no conflicts on both the Primary and
secondary IDE
The slave drive is a Hitachi IC35L120AVV207
http://www.hgst.com/hdd/support/d180gxp/180gxp_ov.htm
And the spec says it is supposed to manage between 59 and 26 MB/sec.
Why is the drive running so slow (at least as reported by the HD Tune tool)
when everything else seems OK?
10 seconds.
are reporting ok.
distortion)
secondary IDE
