Hello guys,
i live in greece and i have an adsl 2(+) up to 24 mbps connection.
I get different speeds depending on the wall jack i use.I have posted it in a greek forum and they said to isolate all the other connection's through the main wall jack so i did.
My maximum speed was 10666 kbps when i isolate the connections.In some jacks i get always 10100 kbps and in some(which i am forced to use due to wifi coverage) is between 7770-8200 kbps depending on how much will the router get when its reset or what the snr is(after 1 day it drops to 9-10 from 11.5).
My attenuation is 33.3db when i use it on a isolated jack and 34.7 when i use it normally.My guess is that the wiring in some point is not made properly or something.
However i still shouldnt be having that speeds.I should be getting 12-14mbps.Please tell me reasons that might make this happen and any way i can test it to see what's happening.
Worth mentioning is that two wall jacks seem to be the "main"ones seem they have more than one connection.I have tested on both.
I am using the ISP's modem/router NetFaster IAD 2 PSTN
Here are some pic's
The one using the isolated wall jack
and here without using
Here are some pic's
