Hi,
So I swapped my motherboard from a Gigabyte GA-H61M-DS2 to a GA-P75-D3. I used to be able to select two playback devices with my old motherboard (GA-H61M-DS2), so one for the rear panel, and one for the front.
I used a Realtek HD Audio Manager and set Disable front panel jack detection:
And I selected Separate all input jacks.. :
I tested the audio and the playback for the front and rear audio is the same:
Is there a way to seperate the front and rear panel to use a different audio playback? Or does the new motherboard (GA-P75-D3) not support this feature?
