[SOLVED] Spun cpu fan backwards while cleaning
IAmAEggHead
8
So I heard that while cleaning your pc you should hold on the fans so that it wouldn't spin.... So I totally did the opposite of that, will there be any problems? I stopped immediately after it started spinning tho, and what's the reason to hold it so that it wouldn't spin?
A short burst of air won't cause any immediate or long term problem for the fan. Prolonged use of high pressured air, either from a can or a compressor will cause the fan bearing to wear out prematurely.
Reactions: IAmAEggHead
