Archived from groups: microsoft.public.windowsxp.security_admin (
More info?)
1) Download the following three items...
Trend Sysclean Package
http://www.trendmicro.com/download/dcs.asp
Latest Trend Pattern File.
http://www.trendmicro.com/download/pattern.asp
Adaware SE (free personal version v1.05)
http://www.lavasoftusa.com/
Create a directory.
On drive "C:\"
(e.g., "c:\New Folder")
or the desktop
(e.g., "C:\Documents and Settings\lipman\Desktop\New Folder")
Download Sysclean.com and place it in that directory.
Download the Trend Pattern File by obtaining the ZIP file.
For example; lpt313.zip
Extract the contents of the ZIP file and place the contents in the same directory as
sysclean.com.
2) Update Adaware with the latest definitions.
3) Disable System Restore
http://vil.nai.com/vil/SystemHelpDocs/DisableSysRestore.htm
4) Reboot your PC into Safe Mode and shutdown as many applications as possible
5) Using both the Trend Sysclean utility and Adaware, perform a Full Scan of your
platform and clean/delete any infectors/parasites found.
(a few cycles may be needed)
6) Restart your PC and perform a "final" Full Scan of your platform using both the
7) Re-enable System Restore and re-apply any System Restore preferences,
(e.g. HD space to use suggested 400 ~ 600MB),
8) Reboot your PC.
9) Create a new Restore point
* * * Please report your results ! * * *
Dave
http://www.claymania.com/removal-trojan-adware.html
"Atlanta Falcons" <AtlantaFalcons@discussions.microsoft.com> wrote in message
news:32B27E33-4ABC-4BBF-985D-8F90D48407F6@microsoft.com...
| Can someI have a spyware problem, I think that whenever i get online that new
| spyware download because I clean it with SpyBot and with McAfee Anti Virus
| and its all gone but i had to quarentin like 4 files with McAfee and all the
| rest i deleted. Than like the next day I clean it and there is alot of them
| again and i dont go to many websites. Can somebody please help?
