SS51G Fan Noise
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.shuttle (More info?)
When I turn on my SS51G XPC, the fan makes a loud buzzing noise for 30secs
to over a minute before quieting down. Should I replace this fan or try to
do the trick I read about where you remove the oil plug and add some machine
oil? I doubt lubricant is the problem because I've only had the computer
for 6 months. If I should replace the fan, does anyone have any
recommendations on reliable and quiet fans that will fit?
Thanks
BigSky
"Big Sky" <bmartin84@cox.net> skrev i en meddelelse
news:1wCce.149$D91.122@fed1read01...
> to
> machine
> Thanks
> BigSky
Don't know if it will do the trick, but do have the latest bios?
After bios update of my sb81p, the fans react differently.
Regards
/SV
