[SOLVED] SSD not running at full speed?
ferdin13
38
So I recently installed a samsung 980 ssd 1 TB NVME on my HP computer, but it is not running at full speed. When I checked crystal disk info and samsung magician, it stated it was running at PCIe Gen 3x2, and doing some research I found out that this is why it was so slow. It is currently only peaking at around 1700 MBPS, and I don't know how to make it faster. I have an HP so the BIOS is crap and there is nothing to change there, and there is only one PCIE slot on my motherboard that should support the full speed.
SPECS:
Intel Core i5-12400F
GTX 1650 SUPER
16 GB DDR4 3200 MHZ
1 TB Samsung 980 SSD
I guess it wouldnt be weird but why would they do that? So theres nothing I can do?
Well - not all M.2 slots are created equal.
Some support only SATA mode, some support NVME (PCIE 3.0), some support NVME (PCIE 4.0), some support PCIE x2, some support PCIE x4.
All this depends on cpu, motherboard, motherboard chipset.
If you have no BIOS configuration options to change M.2 slot settings, then you can't do anything.
BTW - your listed specs do not match model number of your HP pc. It should be Ryzen system (not Intel core i5).
HP Pavilion TG01-2170m Gaming Desktop PC (AMD Ryzen 7 5700G 8-Core, 16GB RAM, 512GB SSD + 1TB HDD, RTX 3060, WiFi, Bluetooth)
HP Pavilion TG01-2170m Gaming PC AMD Ryzen 5 5600G 3.9GHz Processor; NVIDIA...
Why would that be weird?
Different computers, different specs. They have no relation one to another (other than same manufacturer).
Which model HP Pavilion Gaming desktop TG01 ?
That is not a full model name.
HP Pavilion Gaming Desktop TG01-2xxx
HP Pavilion TG01-2170m Gaming PC AMD Ryzen 5 5600G 3.9GHz Processor; NVIDIA GeForce GTX 1660 6GB GDDR5; 8GB DDR4 RAM; 256GB Solid State Drive
Well my PC didn't really have a model number it was custom built by HP and I don't know if that effects models and their naming system is weird, so i dont really know the model number. I would wish to have that PC lol. Thanks for your help then.
I have a very similar issue, put a new nvme drive and am getting very slow, 1700+- both read and write. What can I do to get normal nvme speeds? My system is an HP TG01-2003W Pavilion Ryzen 5 5600G 3.9GHz AMD Radeon RX 5500 4GB .
Thanks for any advice!
Latest posts
