Question SSD wont boot after plugging in RGB controller to the same cable
pop7777
7
Recently swapped cases, SSD booted up without issue and went smoothly for a day or so. I forgot about my LED strips so I installed them etc and it seems that caused something. Ended up connecting the power from the controller into a secondary power slot on the same cable used on my SSD. After that it seems Windows cant start properly. My bios shows my SSD as usual with nothing changed for booting yet it gets stuck on a windows update and now I can't get passed the splash screen. Unfortunately I have no control over any Windows repair options due to a password issue. Not entirely sure if that was the main cause but any advice, suggestions etc is appreciated
TL;DR: SSD wont boot windows after plugging a RGB controller to the same cable
View: https://imgur.com/IPqwmO9
after you get stunk doing windows update, what did you do?
Tried a few methods to cause a repair that either also got stuck like the image i attached or sometimes a brief repair process would show but it immediately tried booting windows soon after (basically also became stuck on the splash screen as a result)
