[SOLVED] Standard VGA? GeForce 9400 GT better than nothing?
You have both right? Run a benchmark on the system as it is. Install the video card and run the same benchmark. Compare scores, you will have an exact answer. You can use something simpler like PassMark if you use 3DMark you will need an older version for that old video card to run the benchmark properly.
Reactions: popicaionica
