[SOLVED] Strange infos from "Fan Control V112"
Apr 30, 2022
28
7
35
Dear Community 😀
I've installed "Fan Control V112" a few days ago and realized, that one fan has a very low and the other an extremely high rpm.
Is that normal, or do I have to look after that?
Many many thanks!
In bios, one fan is always at 0 rpm, maybe its the CPU?
Those do not appear to be accurate readings. Is there some reason why you do not use the free program provided by your motherboard's manufacturer ASUS AI Suite 3 V3.00.69 Program for Windows 10 64-bit to monitor and control your fans?
https://dlcdnets.asus.com/pub/ASUS/...9_PPSU-2.00.55_System_Information-2.00.09.zip
No, there's no reason, except the fact that I didn't know this program existed :sweatsmile:
Many thanks for the advice 😃 I will write you and update this topic, as soon as I tried that program.
Reactions: dwd999
Best program EVER! Many many Thanks to you! 😄😄
Update: One Fan is appearently not correct plugged in, it shows 0rpm and is greyed out. I will try to solve it today ☺
Reactions: dwd999
