I just installed a c2d e8400, and it seems to be working great. That is, except for the fact that bios reports my cpu temp as 84 degrees celsius no matter what (88 according to speedfan.) Weird thing is, the reported temp never changes, and both cores are idling around 30 degrees while my system temp is usually 40-60. Thus far, the system has been totally stable under stress (I tried running mass effect for a bit to see if it so much as slowed down, and it didnt.) Should I be worried, or do I mostly likely have a damaged sensor or something?
