Recently I have had some strange issues with level of detail in my games. Shadow resolution will change at very close distances, or objects will pop in closer then they should. However other then that there seem to be no issues? Has anybody had something similar and if so is there anything I can do? Here is an example from DMC 5. You can see the strange divide in the shadows. This line of detail changes depending on camera position and distance from the shadows.
