Stuck Between the Galaxy S6 Edge and Note 4
FreeManGames
46
My contract is ending soon and I want to make a choice between the Galaxy Note 4 and the Galaxy S6 Edge. I like the Note 4, but the screen is big. I like the idea of the Galaxy S6 except I am sure it will have bad reviews. Should I wait till the release on April 10 or get the Note 4?
I guess it depends on how particular you are. The note series are some of the larger phones out there, and adaptability to a super large phone is a bit subjective. As to internal specs and capabilities, the details differ and the S6 will offer newer components which may be faster, as well as a newer version of Android...
I dont think it will be bad, but I just hate the path they are taking with no removable battery or sd card slot. Although, I will get the 32 GB if I get the S6. I just want to see opinions. What do you think I should get?
The Note 4 is not even a year old yet and it will be a long time till then. I am getting a phone within the next month.
Other than size, is there a big difference between the S6 and the Note 4?
I guess it depends on how particular you are. The note series are some of the larger phones out there, and adaptability to a super large phone is a bit subjective. As to internal specs and capabilities, the details differ and the S6 will offer newer components which may be faster, as well as a newer version of Android. Reportedly the Android image used for the S6 will be "leaner" with less Samsung bloatware too.
If you aren't a super heavy or discriminating user aside from the battery and SD questions, the Note 4 should still be quick and capable.
