My new build cannot completely boot and I'm stumped. My system is listed below MY RIG.
My Symptom:
The system goes through the normal BIOS boot and then hangs when it get to loading windows. When I try to boot in safe mode I see the drivers get loaded. It stops at MUP.sys on the display. I don't know if this is the last driver or the culprit. The LED on my EPOX mobo reads "FF". The system is just hung. It always hangs at the same place.
What I did:
Initially the system booted fine. I loaded windows on it (XP SP2) and everything looked good. I could not access the network, so I figured I had to load the drivers that came with the mobo. I went through the auto install on the driver disk. Once I did that and rebooted, I'm hung. Thinking this might be related to my video card, I pulled it out and booted it with a PCi video card - same result. I removed all the other cards and still I'm hung.
Any ideas??
My Symptom:
What I did:
Any ideas??
