[SOLVED] Stutter issues on most games and some programs running slow
Sep 3, 2021
13
Hey
So basically, a couple of weeks ago I was gaming and having a great time until my PC was crashed on the spot by the game I was playing (LEGO Harry Potter yrs1-4) which resulted in my performance being off slightly in most games. I ended up resetting my system to try and fix the issue but then things just got worse. All of a sudden apps like Discord, Steam and Microsoft Edge (i don't use it but it was never this bad) are running very choppy and most games have significant stutter issues that weren't present before and now I'm not able to game without stopping every 5 mins to fix the gameplay in games like Chernobylite, Crusader Kings 3, Escape from Tarkov, Black Ops 2 and even Stardew Valley.
Things I have tried:
Manually set DRAM voltage
XMP on
Wipe all GPU drivers with DDU
Reinstall older Geforce drivers
Reinstall windows
Completely wiped my SSD partitions and reinstalled windows
Bought extra SSD just for windows
Installed monitor specific drivers
Installed mobo drivers
Change setting via nvidia inspector
Tried G-sync, v-sync (and nvidia reflex on tarkov)
Nothing is working and I'm really hoping my build isn't faulty.
Can anyone point me in the right direction?
Specs:
Monitor: ASUS TUF Gaming VG24VQ @ 144hz
MOBO: MPG Z390 Gaming Pro Carbon AC
CPU: Intel Core i7 9700k
GPU: ASUS ROG Strix RTX 2060 OC 6GB
RAM: Vengeance RGB Pro 16gb (2x 8gb) at 3200mhz
SSD for Windows: KINGSTON SA400S7120G (120gb)
SSD for Storage: Samsung 860 EVO 1TB
PSU: EVGA 600W
You should download and install LatencyMon which will show you what exactly is causing stutter on the software / driver side of things. If there is no high MS stutters from the software then I assume the GPU has a problem. It seems from your prior posts that the GPU is stuck at a low core clock which is also indicative of a GPU problem.
Perhaps after the crash your power settings were changed in windows. What is it set to? What is your memory running at? Do you have any idea why the computer shut down, and has it shut down since?
My PC crashed because of the game I was playing. I'm assuming due to the age of the engine something conflicted and caused my system to shutdown and restart immediately. Power settings set to high performance. Running 16gb of DDR4 ram at 3200mhz (1.350v or auto both run the same)
Try hwmonitor, HWMONITOR | Softwares | CPUID see what your cpu, gpu voltages are doing. Ensure your cpu is running up to speed. Try going to settings, gaming, disable game bar and enable game mode. Then go to display, at the bottom of page you will see graphics settings, enable hardware accelerated graphics and variable refresh rate. See if any of this ehlps.
Hey Fix, sorry for the late reply, I have tried HWMonitor whilst idle and in game and will post the results here maybe you can make more sense of it. The only thing that stands out to me after researching is 1 Power limit but I don't know what it is specifically.
I always have Game DVR and Game mode disabled as they come with microstutters. I have tried hardware accelerated scheduling but it makes no difference. The variable refresh rate is not an available option in the settings for me.
CPUID HWMonitor Report
Binaries
HWMonitor version 1.4.4.0
Monitoring
Mainboard Model MPG Z390 GAMING PRO CARBON AC (MS-7B17) (0x00000976 - 0x6A9435E4)
LPCIO
LPCIO Vendor Nuvoton
LPCIO Model NCT6797
LPCIO Vendor ID 0x5CA3
LPCIO Chip ID 0xD4
LPCIO Revision ID 0x51
Config Mode I/O address 0x4E
Config Mode LDN 0xB
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF 32 C6 10 16 FF FF
20 D4 51 FF 00 00 00 40 00 00 FF 50 00 02 00 00 02
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 0A 20 0A 30 00 00 FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space LPC, base address = 0x0A20
Hardware Monitors
Hardware monitor Nuvoton NCT6796
Voltage 7 0.74 Volts [0x5D] (CPU SA)
Voltage 8 1.11 Volts [0x8B] (CPU VCORE)
Voltage 9 1.36 Volts [0x55] (DRAM)
Voltage 10 12.19 Volts [0x7F] (+12V)
Voltage 11 5.08 Volts [0x7F] (+5V)
Voltage 12 0.71 Volts [0x59] (CPU I/O)
Voltage 13 1.06 Volts [0x84] (PCH)
Voltage 15 3.41 Volts [0xD5] (+3.3V)
Temperature 5 43 degC (109 degF) [0x2B] (MOS)
Temperature 6 41 degC (105 degF) [0x29] (System)
Temperature 8 39 degC (102 degF) [0x27] (CPU Socket)
Temperature 9 43 degC (109 degF) [0x2B] (CPU Core)
Fan 1 725 RPM [0x2D5] (CPU)
Fan 2 986 RPM [0x3DA] (SYS fan 2)
Fan 3 943 RPM [0x3AF] (SYS fan 4)
Fan 4 930 RPM [0x3A2] (SYS fan 3)
Fan 6 936 RPM [0x3A8] (SYS fan 5)
Hardware registers
bank 0
00 03 FF 03 29 00 FF FF FF FF FF FF FF FF FF FF FF
10 03 93 03 93 03 93 03 93 40 85 5D 5E 84 55 C3 00
20 6F 7F D1 D5 7F 13 59 29 03 93 FF DA 00 00 00 00
30 00 00 00 00 00 00 00 00 00 50 4B FF FF FF FF FF
40 23 00 07 DF FF 08 2F FF 2D FF FF 10 00 55 00 A3
50 15 FF FF FF FF FF FF FF C1 FF FF FF FF 02 02 01
60 41 F0 FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
70 00 0A 00 29 80 29 80 29 80 29 80 29 80 29 80 FF
80 FF 7F 7F BF FF 05 05 05 00 00 00 00 00 00 00 00
90 0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
A0 0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 01 00
B0 00 00 00 00 00 00 37 00 04 00 00 0A E8 40 04 00
C0 FF FF FF FF FF FF FF FF FF 0F 01 05 FF FF FF FF
D0 05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
E0 55 80 00 00 00 FF FF FF FF 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 FF 1C 10 62 00 37 FF FF FF
bank 4
00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF
10 FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF FF
20 FF FF FF 96 64 96 64 E1 96 00 4C 13 A0 3C 60 03
30 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF 00 00 FF FF FF FF FF FF 00 00 00 00 04 FF
50 01 FB FF FF 00 00 00 FF FF 0E 53 31 09 00 FF FF
60 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 6F 7F D1 D5 7F 13 59 D1 00 85 5D 5E 84 55 C3 00
90 29 2B 2A 28 27 FB 00 37 FF 29 29 29 29 29 1F 29
A0 29 29 FF FF FF FF FF 29 93 93 93 00 00 00 00 00
B0 FF 1F 3A 00 2B 0D 2C 16 2D 08 FF 1F 00 93 93 00
C0 00 00 02 D7 03 CB 03 B0 03 A4 00 00 2D 07 03 A4
D0 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
E0 FF 29 93 93 93 93 93 FF FF FF FF FF FF FF FF FF
F0 29 C0 00 00 29 00 00 00 00 00 00 00 00 00 00 FF
Hardware monitor DIMM
Temperature 0 42 degC (108 degF) [0xC2A4] (core)
Temperature 0 42 degC (107 degF) [0xC29C] (core)
Hardware monitor MSI MCU
Voltage 0 1.20 Volts [0x4AD] (CPU IO)
Voltage 1 1.15 Volts [0x47B] (CPU SA)
Register space WIN32 HID
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 0.71 Volts [0x2C8] (GPU)
Power 0 25.47 W (GPU)
Temperature 0 40 degC (104 degF) [0x28] (GPU)
Temperature 2 52 degC (125 degF) [0x34] (Hot Spot)
Fan 0 1325 RPM [0x52D] (GPU #0)
Fan 1 1327 RPM [0x52F] (GPU #1)
Clock Speed 0 420.00 MHz [0x1A4] (Graphics)
Clock Speed 1 405.00 MHz [0x195] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
CPU Groups 1
CPU Group 0 8 CPUs, mask=0xFF
Number of sockets 1
Number of threads 8
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 2)
-- Thread 1 2
-- Core 2 (ID 4)
-- Thread 2 4
-- Core 3 (ID 6)
-- Thread 3 6
-- Core 4 (ID 8)
-- Thread 4 8
-- Core 5 (ID 10)
-- Thread 5 10
-- Core 6 (ID 12)
-- Thread 6 12
-- Core 7 (ID 14)
-- Thread 7 14
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 8 (max 8)
Number of threads 8 (max 8)
Manufacturer GenuineIntel
Name Intel Core i7 9700K
Codename Coffee Lake
Specification Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
Package (platform ID) Socket 1151 LGA (0x1)
CPUID 6.E.D
Extended CPUID 6.9E
Core Stepping R0
Technology 14 nm
TDP Limit 95.0 Watts
Tjmax 100.0 °C
Core Speed 4601.1 MHz
Multiplier x Bus Speed 46.0 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 100.0 MHz
Stock frequency 3600 MHz
Max frequency 4900 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX, AVX2, FMA3
Microcode Revision 0xDE
L1 Data cache 8 x 32 KB (8-way, 64-byte line)
L1 Instruction cache 8 x 32 KB (8-way, 64-byte line)
L2 cache 8 x 256 KB (4-way, 64-byte line)
L3 cache 12 MB (12-way, 64-byte line)
Max CPUID level 00000016h
Max CPUID ext. level 80000008h
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 36x
Max turbo ratio 49x
Max efficiency ratio 8x
Speedshift Autonomous
O/C bins unlimited
Ratio 1 core 49x
Ratio 2 cores 48x
Ratio 3 cores 48x
Ratio 4 cores 47x
Ratio 5 cores 47x
Ratio 6 cores 46x
Ratio 7 cores 46x
Ratio 8 cores 46x
IA Voltage Mode PCU adaptive
IA Voltage Offset 0 mV
GT Voltage Mode PCU adaptive
GT Voltage Offset 0 mV
LLC/Ring Voltage Mode PCU adaptive
LLC/Ring Voltage Offset 0 mV
Agent Voltage Mode PCU adaptive
Agent Voltage Offset 0 mV
TDP Level 95.0 W @ 36x
Temperature 0 40 degC (104 degF) (Package)
Temperature 1 38 degC (100 degF) (Core #0)
Temperature 2 39 degC (102 degF) (Core #1)
Temperature 3 40 degC (104 degF) (Core #2)
Temperature 4 39 degC (102 degF) (Core #3)
Temperature 5 38 degC (100 degF) (Core #4)
Temperature 6 38 degC (100 degF) (Core #5)
Temperature 7 40 degC (104 degF) (Core #6)
Temperature 8 38 degC (100 degF) (Core #7)
Voltage 0 +0.00 Volts (IA Offset)
Voltage 1 +0.00 Volts (GT Offset)
Voltage 2 +0.00 Volts (LLC/Ring Offset)
Voltage 3 +0.00 Volts (System Agent Offset)
Voltage 4 1.29 Volts (VID #0)
Voltage 5 1.26 Volts (VID #1)
Voltage 6 1.26 Volts (VID #2)
Voltage 7 1.25 Volts (VID #3)
Voltage 8 1.24 Volts (VID #4)
Voltage 9 1.24 Volts (VID #5)
Voltage 10 1.23 Volts (VID #6)
Voltage 11 1.28 Volts (VID #7)
Power 00 14.09 W (Package)
Power 01 7.62 W (IA Cores)
Power 02 n.a. (GT)
Power 03 6.46 W (Uncore)
Power 04 0.72 W (DRAM)
Clock Speed 0 4601.10 MHz (Core #0)
Clock Speed 1 4701.13 MHz (Core #1)
Clock Speed 2 4701.13 MHz (Core #2)
Clock Speed 3 4701.13 MHz (Core #3)
Clock Speed 4 4701.13 MHz (Core #4)
Clock Speed 5 4701.13 MHz (Core #5)
Clock Speed 6 4701.13 MHz (Core #6)
Clock Speed 7 4701.13 MHz (Core #7)
Core 0 max ratio 49.0 (effective 49.0)
Core 1 max ratio 49.0 (effective 49.0)
Core 2 max ratio 49.0 (effective 49.0)
Core 3 max ratio 49.0 (effective 49.0)
Core 4 max ratio 49.0 (effective 49.0)
Core 5 max ratio 49.0 (effective 49.0)
Core 6 max ratio 49.0 (effective 49.0)
Core 7 max ratio 49.0 (effective 49.0)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 12 MB, 16 thread(s)
CPUID
0x00000000 0x00000016 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000906ED 0x00100800 0x7FFAFBFF 0xBFEBFBFF
0x00000002 0x76036301 0x00F0B6FF 0x00000000 0x00C30000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004143 0x00C0003F 0x000003FF 0x00000000
0x00000004 0x1C03C163 0x02C0003F 0x00003FFF 0x00000006
0x00000005 0x00000040 0x00000040 0x00000003 0x11142120
0x00000006 0x000027F7 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x029C67AF 0x40000000 0xBC000600
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300804 0x00000000 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x0000001F 0x00000440 0x00000440 0x00000000
0x0000000D 0x0000000F 0x00000440 0x00000100 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x0000000D 0x00000040 0x000003C0 0x00000000 0x00000000
0x0000000D 0x00000040 0x00000400 0x00000000 0x00000000
0x0000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x00000010 0x00000000 0x00000000 0x00000000 0x00000000
0x00000011 0x00000000 0x00000000 0x00000000 0x00000000
0x00000012 0x00000000 0x00000000 0x00000000 0x00000000
0x00000013 0x00000000 0x00000000 0x00000000 0x00000000
0x00000014 0x00000001 0x0000000F 0x00000007 0x00000000
0x00000015 0x00000002 0x0000012C 0x00000000 0x00000000
0x00000016 0x00000E10 0x00001324 0x00000064 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000121 0x2C100800
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x3037392D 0x43204B30 0x40205550
0x80000004 0x362E3320 0x7A484730 0x00000000 0x00000000
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003027 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x0000003A 0x00000000 0x00020005
MSR 0x00000035 0x00000000 0x00080008
MSR 0x000001A0 0x00000000 0x00850089
MSR 0x00000770 0x00000000 0x00000001
MSR 0x00000774 0x0000019E 0x0000FF24
MSR 0x000000CE 0x08080838 0xF1012400
MSR 0x00000017 0x00040000 0x00000000
MSR 0x000000C1 0x00000000 0x00000000
MSR 0x000000C2 0x00000000 0x00000000
MSR 0x000000C3 0x00000000 0x00000000
MSR 0x000000C4 0x00000000 0x00000000
MSR 0x00000186 0x00000000 0x00000000
MSR 0x00000187 0x00000000 0x00000000
MSR 0x000001AD 0x2E2E2E2F 0x2F303031
MSR 0x00000194 0x00000000 0x000F0000
MSR 0x0000019A 0x00000000 0x00000000
MSR 0x000001A4 0x00000000 0x00000000
MSR 0x000001B1 0x00000000 0x88360008
MSR 0x000001FC 0x00000000 0x0038005D
MSR 0x00000606 0x00000000 0x000A0E03
MSR 0x00000601 0x00000000 0x00000000
MSR 0x00000610 0x004287F8 0x00DD87F8
MSR 0x00000611 0x00000000 0x084FE6EF
MSR 0x00000639 0x00000000 0x04FF5429
MSR 0x00000641 0x00000000 0x00000000
MSR 0x00000619 0x00000000 0x0077B4AB
MSR 0x00000614 0x00000000 0x000002F8
MSR 0x00000648 0x00000000 0x00000024
MSR 0x00000649 0x00000000 0x00000000
MSR 0x0000064A 0x00000000 0x00000000
MSR 0x00000198 0x00002702 0x00002E00
MSR 0x00000199 0x00000000 0x0000FF00
CPU Thread 1
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x000906ED 0x02100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x0000001B 0x00000000 0xFEE00800
MSR 0x000001B1 0x00000000 0x88350008
MSR 0x00000611 0x00000000 0x08501374
MSR 0x00000639 0x00000000 0x04FF7D46
MSR 0x00000619 0x00000000 0x0077B5BE
MSR 0x00000198 0x00002732 0x00002E00
MSR 0x00000199 0x00000000 0x00002400
CPU Thread 2
APIC ID 4
Topology Processor ID 0, Core ID 4, Thread ID 0
CPUID
0x00000001 0x000906ED 0x04100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x00000611 0x00000000 0x08503EBA
MSR 0x00000639 0x00000000 0x04FFA4FF
MSR 0x00000619 0x00000000 0x0077B726
MSR 0x00000198 0x0000281C 0x00002E00
CPU Thread 3
APIC ID 6
Topology Processor ID 0, Core ID 6, Thread ID 0
CPUID
0x00000001 0x000906ED 0x06100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x000001B1 0x00000000 0x88340008
MSR 0x00000611 0x00000000 0x08506AB9
MSR 0x00000639 0x00000000 0x04FFCF6C
MSR 0x00000619 0x00000000 0x0077B853
MSR 0x00000198 0x00002739 0x00002E00
CPU Thread 4
APIC ID 8
Topology Processor ID 0, Core ID 8, Thread ID 0
CPUID
0x00000001 0x000906ED 0x08100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x00000008
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000008
MSR 0x00000611 0x00000000 0x0850AAD9
MSR 0x00000639 0x00000000 0x05000CD2
MSR 0x00000619 0x00000000 0x0077BA02
MSR 0x00000198 0x00002932 0x00002F00
CPU Thread 5
APIC ID 10
Topology Processor ID 0, Core ID 10, Thread ID 0
CPUID
0x00000001 0x000906ED 0x0A100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x0000000A
0x0000000B 0x00000004 0x00000008 0x00000201 0x0000000A
MSR 0x00000611 0x00000000 0x0850ED97
MSR 0x00000639 0x00000000 0x05004BA9
MSR 0x00000619 0x00000000 0x0077BBAF
MSR 0x00000198 0x00002919 0x00002F00
CPU Thread 6
APIC ID 12
Topology Processor ID 0, Core ID 12, Thread ID 0
CPUID
0x00000001 0x000906ED 0x0C100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x0000000C
0x0000000B 0x00000004 0x00000008 0x00000201 0x0000000C
MSR 0x00000611 0x00000000 0x0851269D
MSR 0x00000639 0x00000000 0x050080FD
MSR 0x00000619 0x00000000 0x0077BD63
MSR 0x00000198 0x00002942 0x00002F00
CPU Thread 7
APIC ID 14
Topology Processor ID 0, Core ID 14, Thread ID 0
CPUID
0x00000001 0x000906ED 0x0E100800 0x7FFAFBFF 0xBFEBFBFF
0x0000000B 0x00000001 0x00000001 0x00000100 0x0000000E
0x0000000B 0x00000004 0x00000008 0x00000201 0x0000000E
MSR 0x00000611 0x00000000 0x0851588B
MSR 0x00000639 0x00000000 0x0500AF83
MSR 0x00000619 0x00000000 0x0077BEA7
MSR 0x00000198 0x00002869 0x00002F00
Storage
Drive 0
Name Samsung SSD 860 EVO 1TB
Revision RVT04B6Q
Serial S4X6NJ0N302821Y
Capacity 931.5 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Controller Serial ATA Controller - AHCI at bus 0, device 23, function 0
Volume d:\, 931.5 GBytes (96.3 percent available)
Drive 1
Name KINGSTON SA400S37120G
Revision 03090005
Serial 50026B7380FFF9C4
Capacity 111.8 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume c:\, 111.2 GBytes (50.6 percent available)
USB Devices
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x258A, product=0x001A
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0xC084
USB Device Xbox Wireless Adapter for Windows, class=0x00, subclass=0x00, vendor=0x045E, product=0x02FE
USB Device USB Input Device, class=0x00, subclass=0x00, vendor=0x1462, product=0x7B17
USB Device USB Composite Device, class=0x00, subclass=0x00, vendor=0x046D, product=0x0A9C
USB Device Generic USB Hub, class=0x09, subclass=0x00, vendor=0x05E3, product=0x0608
USB Device Intel(R) Wireless Bluetooth(R), class=0xE0, subclass=0x01, vendor=0x8087, product=0x0AAA
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x10A0106
Name NVIDIA GeForce RTX 2060
Board Manufacturer ASUSTeK Computer Inc.
Revision A1
Codename TU106-200A
Core family 0x166 (TU106-A)
TDP 175.0 W
Cores 1920
ROP Units 48
TM Units 120
RayTracing Cores 30
Tensor Cores 240
Technology 12 nm
Memory type GDDR6 (Micron)
Memory size 6 GB
Memory bus width 192 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1043)
Model ID 0x1F08 (0x868E)
Revision ID 0xA1
Root device bus 0 (0x0), device 1 (0x1), function 0 (0x0)
Performance Level Base
Core clock 1365.0 MHz
Memory clock 7001.0 MHz
Performance Level Boost
Core clock 1830.0 MHz
Performance Level Current
Core clock 420.0 MHz
Memory clock 405.0 MHz
Driver version 30.0.14.7196
WDDM Model 2.7
Monitor 0
Model ASUS VG24V ()
ID AUS2420
Serial
Manufacturing Date Week 39, Year 2020
Size 23.4 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 180-180 kHz
Vertical Freq. Range 48-144 Hz
Max Pixel Clock 340 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
Makes no difference 🙁
My first post and you guys are light years ahead of me but I read your post with interest as I have had a similar stutter issue with my cursor movement and recently I'm getting some sort of page up on typing. Grr.
Scot, you've looked at a few things already and the clues seem to be slowing down. I see you have a Samsung SSD. I have a Samsung SSD 850 EVO 500GB with an i5 5300U and 12Gb ram into an onboard HD Graphics 5500 GPU. I'm running a Logitech G604 mouse which I wondered if it doesn't load up properly and I've also recently started using an old cordless Logitech keyboard which has a dedicated USB receiver. I'm running Win10/64. So I don't know if these are some clues or some red-herrings for you... I came here looking for info on apps in Win10, so well and truely side-tracked.
I'm using a Logitech G203 but don't have stuttering with my cursor movement or up-scrolling problems. It's mainly within games and some applications that I am noticing choppy performances.
Have you tried any of the things in my initial post? Are you using a Laptop? If so, it could be that the mouse is interfering with your on-board touchpad. Try updating drivers or disabling the touch-pad completely.
So when you play your games open task manager and look at the processes that are open. Is there anything there that is taking up resources?
I’ll check and let you know, but I usually keep an eye on that and it shouldn’t be the culprit of my issues. Yes my RAM is running at 3200mhz , displayed with that speed on Task Manager and on my BIOS
