I need some help with a system which refuses to POST, beep, or give any type of video output. I already tried various troubleshooting measures, which are summarized below.
First of all, the system features the following components:
Questions:
- Mainboard: Supermicro X11DPL-i (dual-socket board)
- CPU: 1x Intel Xeon 5220R LGA3647 Cache Boxed
- CPU cooler: Noctua NH-U14S DX-3647
- RAM: 4 x Kingston 32GB DDR4-2666MHz Reg ECC Module (DIMM 288)
- PSU: Corsair HX750
- GPU (removed for debugging): Zotac GeForce RTX 3090 Gaming Trinity (24GB)
- Storage: SSD Samsung 970 EVO Plus, 1TB, M.2 2280
- Case: Corsair Carbide 678C (Midi Tower, Insulated)
- On a good note, when the system is turned on, the fans of the case and the CPU cooler start spinning; if the GPU is attached, the GPU fans start spinning as well.
- All the LEDs on the mainboard which indicate some status blink the way they should according to the manual, i.e. LE1 solid blue = unit identified, LE6 solid green = power on (when turned on), and LEDM1 blinking green = BMC normal.
- No POST, no beep tones from the mainboard at all when system is turned on.
- No video output; neither when operated without the discrete GPU (= GPU removed from case) via the VGA of the mainboard, nor when the screen is connected to the discrete GPU.
- Removed mainboard from the case, tested the whole system with the board on an external antistatic surface.
- Removed RAM one by one, also tested to boot without any RAM.
- Changed CMOS battery, cleared BIOS by touching JBT1 contact pads.
- Checked with GPU included (HDMI and DisplayPort to different external screens) and with GPU removed (VGA to different external screens, to make sure that the screen was not the problem). All cables were from other setups and work fine there.
- Removed other connections or hardware one by one (e.g. SSD, USB connector, fans, etc.).
- Tested with and without input devices such as mouse and keyboard attached.
- Checked that the connections from mainboard to PSU are properly attached, and they should be; 1x 24-pin ATX main power supply connector and 2x 8-pin CPU power connectors, as specified in the manual. When inserted, the GPU is connected with two separate 6+2-pin connectors to the 2 8-pin slots in the PSU. I only used cables that came with the PSU.
- Checked that I indeed populated the primary CPU socket with the CPU, attached the RAM to the proper sockets when operating only socket 1 with 4 RAMs, and put the GPU in the right PCI-E slot for CPU1.
- Starting without CPU: The turn-on button then does not have any visible effect, mainboard LE6 remains on red (= standby, this is the normal behavior of LE6 before the system is turned on).
- Please note that I unfortunately don't have any other LGA3647 CPU, mainboard, RAM, or different PSU, so I could not check the system with those swapped.
Questions:
- Did I miss any troubleshooting steps which may resolve the issue?
- The mainboard is specified to work up to a TDP of 140 W, while the CPU is 150W. Could this be the culprit? (When I talked to the mainboard company's support and stated my CPU, they did not seem to see any incompatibility, but I started to wonder about this because on their Q&A site some people were asking about CPU compatibility with surpassing the mainboard's TDPs, and the answer there states that it would cause issues.)
