I built a new system a few weeks ago and have been slowly fighting with it, trying to figure out some issues I think are for to RAM. It's my first Ryzen build and I've read that Ryzen is fairly tied to the memory accompanying it. System specs below.
CPU: Ryzen 7 3700x
Memory: G.Skill Trident Z RGB 3600mhz (2x16GB)
Mobo: Gigabyte x570 Aorus Elite
GPU: ASRock Challenger RX 5700 XT
Case: Corsair 275R w/ 6 AF120 case fans
I started noticing issues when I would play steam games. Some of the not demanding games will occasionally just close without any warning or error messages.
I have XMP enabled on my RAM. After doing some research, I decided to run memtest, though I should have done that from the beginning. Memtest passed all tests with no errors with RAM clocked at 3600mhz. So then I booted up the machine and ran Prime95 blend test. Several threads fail with the following (or similar) error almost immediately.
Fatal error: rounding was .5, expected less than .4
The longer I let it run, the more threads fail. I then ran a short Prime95 Small FFT and Medium FFT test and didn't see any issues. When running the Large FFT test, I see the errors but it takes longer than in a blend test.
I tried bumping XMP settings down to 3466 instead of 3600, with no change in results.
I thought it might be thermals related, but during these tests, the CPU isn't getting over 65c. I don't have temps on the memory but I have a hard time believing the memory should have thermal issues if the CPU and GPU are running fine.
I'm honestly not sure what other things I should be looking at, other tests I should run, or if this is indicative of a CPU issue or a RAM issue. What I've seen makes me think it's a RAM issue. Is this an issue with RAM thermals? Does that mean the RAM is bad and I should RMA it or should I be do something else to improve cooling?
CPU: Ryzen 7 3700x
