Suspicious Packets Using Yproxy
G
Guest
Guest
Archived from groups: comp.security.firewalls (More info?)
Like many others, I use Yproxy to decode yenc files. I also run Agnitum
Firewall Pro.
Strangely, -after- I disconnect from Yproxy, the firewall reports
"suspicious packets" from Yproxy, presumably running a port scan.
Is this normal, or should I be alarmed?
Thanks,
Chas.
Can you provide more information, like what specific activity is reported?
In particular, what protocol and what are the source and destination ports
and addresses?
"Chas." <person@humankind.net> wrote in message
news:411037f6$0$449$c3e8da3@news.astraweb.com...
> Firewall Pro.
> Thanks,
> Chas.
I get reports of "suspicious packets" from the Yproxy site itself, just as I
disconnect from it. The packets are sent to a different port each time.
Chas.
"Nobody" <nobody@nowhere.com> wrote in message
news:C0wQc.21111220$Id.3497445@news.easynews.com...
> and addresses?
> > Firewall Pro.
> > Thanks,
> > Chas.
I think you mean when you connect. Look up the topic "Message of the Day" in yProxy's help file. When you start the yProxy server, yProxy polls the website for a message of the day via HTTP, just like a web browser. The web server responds via HTTP indicating that there is no message of the day.
If you look at the packets, you'd see this.
