Archived from groups: comp.dcom.lans.ethernet (
More info?)
"T. Sean Weintz" <sean@snerts-r-us.org> wrote in message
news:10bc0rcb7rm197d@corp.supernews.com...
> JJ wrote:
> > I have three switches, they are daisy chained.
> > Would I see better performance if I had two of the switches directly
> > connected ( home run ) to the third switch as opposed to running threw
each
> > other.
> > If yes, could someone point me in the right direction to figure this
out.
> > Thanks
> > JJ
> generally, it's best to put the two switches both connected to the
> third, and have all servers plugged into the third as well. Any switch
> will give SOME latency (although usual so small as to be pretty much
> unmeasurable from the workstation)
i suggest the main reason for this is to do with system bandwidth.
Your recommended layout has 1 switch as a star point for other switches and
servers. This gives the highest overall system bandwidth (as long as the
backplane within the switch is faster than the switch to switch links -
which should be true by an order of magnitude or more for any reasonable
modern hardware).
> Copyright 2004 T. Sean Weintz
> This post may be copied freely without
> the express permission of T. Sean Weintz.
> T. Sean Weintz could care less.
> T. Sean Weintz is in no way responsible for
> the accuracy of any information contained in
> any usenet postings claiming to be from
> T. Sean Weintz. Users reading postings from
> T. Sean Weintz do so at their own risk.
> T. Sean Weintz will in no way be liable for
> premature hair loss, divorce, insanity,
> world hunger, or any other adverse relults
> that may arise from reading any usenet
> posting attributed to T. Sean Weintz
Regards
Stephen Hope - return address needs fewer xxs
