SO, I ordered and install new corsair vengence rgb pro 16gb (2x8) 3600mhz sticks in my prebuilt Intel setup.
Had one single 8gb stick of xpg 2666 in it when purchased.
The mobo/chip is an asus prime b360m-a
Intel i5 9400f.
When I turned on the tower after install, everything booted visually normal.
All the fans, and even the rgb on the ram started cycling, but I got no display, monitor just says no input.
Tried swapping cables. Swapping slots, all that. Placed the socks in a2-b2 per mobo manual instructions, tried doing the battery removal reset, all that. I even tried putting my 1x8gb stick of xpg ram back in with the same issue
I've searched and read and tried to find solutions, I'm new to the building/modification part of PC's and I don't wanna screw it up anymore than I have.
What have I done wrong, and how do I fix it!?
Thanks, Josh
Intel i5 9400f.
Thanks, Josh
