Crashman :
cyanna :
Missing info from the article: you can't use that motherboard with that CPU OOB!!!! The bios needs to be flashed to v 3.4 before you can do anything. I think this should be mentioned in the article because a home us
It's not mentioned because it's not true. If you buy from a company that frequently turns over stock such as Newegg, you're going to receive the board with a compatible BIOS.
You'd think so, but that's definitely not always the case, as I'm sure many here can attest to. In fact, if you just take a moment to read the comments on Newegg from verified owners, this becomes obvious (not necessarily on this product, but many, many others).
The fact is, it's not Newegg's responsibility to flash a BIOS, anyway. They'll sell the stock they have, probably oldest first.
I actually purchased a Gigabyte GTX 770 4GB about 2 1/2 months ago, and just purchased another about two weeks ago. When I received the new one, I noticed the packaging was a bit different, the cooler was slightly different and there were two 8-pin connectors instead of and 8 & 6... it was a Rev 2.0 version. The other was a revision 1. The 2nd revision was released quite a while ago, so it's clear they had the 2nd and 1st on hand at the same time. Both cost exactly the same and both were ordered from EXACTLY the same URL (i.e. I had no version choice.).
The point is simple: you never know unless the version is specified, and even then a BIOS revision can't be expected on what you receive. I usually assume I need to check all BIOS versions on all hardware before expecting it to function properly.
What he posted was correct: the board may need a BIOS update, but this should be expected by any experienced builder. That said, it wouldn't hurt to mention that support for this CPU wasn't originally spec'd in this board.
