G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I'm trying to load CD tutorial for work on my PC. At first when trying to
run from the D: drive I got an error stating '16 bit Windows Subsystem
c:\window
system32\autoexec.nt The system file is not suiting for running MS-DOS and
Miscrosoft Windows Applications. Choose 'Close' to Terminate the
Application.' Choosing Close or Ignore both did nothing. After following
instruction to run the windows/repair and copy and past autoexec.nt and
config.net into the windows/system32 folder (applying read-only), I've
encounter a new error when trying to run the CD... not it says File Error:
Cannot find SHELL.DLL
after hitting OK, i get Install: System DLLs corrupt or missing.
What do I do!?!?!?!
Thx
c:\window
What do I do!?!?!?!
Thx
