[SOLVED] System lag needs frequent reboot
amtang3
Commendable
Oct 25, 2017
Hello,
I am at a loss to figure out why my PC frequently needs a reboot in order get rid of system lag that occurs over time. How long it takes for the lag to occur can vary but sometimes its within 12 hours at other times it could take a few days. When I say lag what I am referring to is very slow response times to any user input from either the keyboard or mouse. Sometimes it could take more than 5 seconds for a response. I built the PC myself with the components below with Windows 10 as the OS.
Any help on how troubleshoot and isolate the issue would be helpful. I also use Bitdefender as my antivirus and I also use System Mechanic to diagnose system issues.
Here are my system specs:
ComponentBrandSpecification
MotherboardMSIGIGABYTE X470 AORUS GAMING 5 WIFI
CPU AMDRyzen 5 1600X
RAMKingstonKingston Technology HyperX Fury Black 32GB 3200MHz DDR4 CL18 DIMM
Graphics CardEVGAGeForce GTX 970 4GB GDDR5
Hard DriveSamsung500GB 2.5-Inch SATA III SSD
Power SupplyEVGAEVGA 750 GQ, 80+ GOLD 750W
Here are screens from Resource Monitor:
https://docs.google.com/presentatio...ArXpgj/pub?start=true&loop=true&delayms=60000
you have a lot of software you could disable at start up if you dont need them check this with glary utilities dont touch any from the os .
