My last headset was working through USB so everything was fine, but the new headset I bought is using 3.5mm audio jack, and a weird behaviour is happening.
My friends told me that they can hear me watching a youtube video, at first I though it is just the microphone that picks up the audio from my headphones but after hours of fiddling around, I found out that even when I totally mute the sound on my headset the audio is still being picked up and used as input. I went even further and completely unplugged the microphone from my headset and the audio is still being picked up!
The main plug is a TRRS connector (3 black rings).
It's worth mentioning that I already have adapter delivered with this headset which I use to connect it to my pc as it splits the jack into two TRS because I can't connect it in any other way. Also, I tested the headset with my laptop which has one TRRS port and there is still sound without microphone but it is much much quieter and needs quite a volume to be heard but on the other hand has a lot of white noise while my PC has no white noise at all but the audio picked up is much louder.
Anyone has any idea how to fix this?
I tried these methods:
- Disabling Stero Mix
- Lowering dB gain
- Turning on various background noise remover technologies.
