Hello, I have some questions in regards to System Restore:
1. Does System Restore effect the settings for Folder Auditing? which can be found under properties -> security tab -> Auditing.
2. Also, is this setting saved in the registry which means that System Restore would undo that change for that particular setting? Like how most settings are saved in the registry and can be undone by performing a System Restore.
Your help is greatly appreciated, Thank you in advance!
