G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
(XP Home SP2)
Hi - I know that the 'system state' option in NTbackup is limited to
system files, and system restore tries to cover files all over the
computer. But I find that using system restore can have some
non-intuitive behavior (nothing serious, but sometimes it doesn't quite
get everything the way I would expect in outlying folders), and I'm
wondering. If all I'm going to do is install a piece of software, and
I'm concerned that I won't like it and immediately do an uninstall, is
it safer to use system state backup and restore (knowing that this won't
effect anything out of the system areas, which is an advantage in this
case), rather than to risk the possibly more substantial behavior of a
system restore operation for something this minor. System restore
strikes me as something to use when you have to go back days, rather
than minutes, and you're willing to have to do some cleanup to get
everything right again.
thanks!
/j
(XP Home SP2)
thanks!
/j
