Hello, I have build a few PC's before and never had this issue before. As far as I know I put all the cables into their position and all the components as well. The problem however is once I try to power on the system, nothing happens. I think it might be the powersupply, since the fan inside moves a tiny bit and nothing else seems to happen. Does anyone know a solution? Is the powersupply broken or might is be something else? If you'd like more information I'm happy to let you know.
The system consists off:
CPU: AMD Ryzen 5 5600g
GPU: AMD RX 6650 xt
Motherboard: Gigabyte A520M H
PSU: EVGA W1 700w 80+ White
SSD M. 2: Lexar NM710
MEMORY: Corsair DDR4 Vengeance lpx 3200
GPU: AMD RX 6650 xt
