t-rex help
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
t-rex on jp is only going about 1/2 way down then the motor just
shutters.
if i give it a little push it will go again.
it was working fine and just started doing this.
anyone know whats going on?
thanks
john
Gears, unfortunately, it seems. Time for a new assembly. Multiproducts
really makes it hard to open it up and fix it, as I recently tried with POA
motor assembly. New unit is the only solution.
Adi
www.txpinball.com
"Keith Stelter" <stelter@qtm.net> wrote in message
news:42eecf0a$1_1@spool9-west.superfeed.net...
> Probably a stripped gear or at least some broken teeth on a gear inside
the
> gearbox.
> I have had some luck taking these apart (you have to drill rivets, etc)
and
> moving the gears on the shafts so that "good" areas of the gears are
> contacting each other, but it's a pretty ambitious task.
> Last time I bought a T-rex motor/gearbox assembly it was about $100.00.
> "kansas city pinball.com" <rgp@johncglennon.com> wrote in message
> news:1122943036.599183.273680@g49g2000cwa.googlegroups.com...
> > shutters.
> > thanks
> > john
> ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet
News==----
> http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+
Newsgroups
> ----= East and West-Coast Server Farms - Total Privacy via Encryption
Steve Young should have them, he made a deal with Multiproducts.
Adi
www.txpinball.com
news:1122952871.997674.25460@g43g2000cwa.googlegroups.com...
> who sells them?
> john
