TECH: HELP! TZ gumball stopped operating
G
Guest
Guest
Archived from groups: rec.games.pinball (More info?)
Hi folks,
Just finished cleaning my playfield with the Treasure-Cove kit, and put
a layer of wax on, then started to play.
i loaded one ball in the gumball for a toal of 4, so one should pop
out, as it always has done. The knob tries to turn then stops.
So, I forced the left/right ramp combo to try one more ball. same
thing.
Now I have 4 balls in the gumball(3 of them are down in the "carousel"
holes that turn for them to drop out.....
I went through all the test, but can't find one to exercise the
gumball to try to figure out what is going on.
The gumball has worked absolutely perfectly since I got the TZ about a
month ago..
Now, of course, since there are only 3 balls in the out hole area, it
will not advance a ball to the trough..
help, please......
Hi Lloyd,
I found test T17(gumball test). I am running 9.4h.
I have four balls in the 4 carousel positions in the bottome of the
gumball. when the machine starts the test, the carousel rotates, but
no ball comes out the front. the autoshooter fires a ball in, the
carousel turns again inside the gumball, but the knob does not turn
and no ball comes out.....
it seems like electrical is good, filling the machine is no problem,
turning the carousel works, it just won't pop out a ball.
Incidentally, when the carousel turns each time, it seems stuck at
first, then turns abruptly......
I am now getting an error message, "gumball error check geneva
switch"......
lloyd, thanks so much for helping me real time on this!
first off, I found the Geneva switch from searching past posts. both
the green and white leads are still soldered on.
ok, I removed the vertical, plastic feeder plastic out of the
machine, and there are NO balls that I can remove. all four have
dropped down into the 4 positions on the carousel that tries to turn.
sorry,
actually, I have 3 balls in the carousel, the 4th ball position is
empty, and I have 2 balls in the trougth.......hum......sounds like a
ball somehow jammed in the bottom of the gumball when trying to
release, is that possible?
ok, I'm a dope, I found the 6th ball, it's in the wire ramp above the
gumball maching since I had the pf turned upward.....do'h....
no, unfortunately.
when I run the test, one of two things happens:
1. the carousel and knob turn, but it's not a smooth turn like I see
during gameplay. It's a quick, violent turn.
or
2. the carousel and knob try to turn left, then right, then stop and I
get the Geneva switch error message...
no.
when running the gumball tests, one of two things will happen:
the carousel will turn along with the knob on the front, but it's not
the smooth turn like I see during gameplay. The knob and carousel
turn very fast and violently, and no ball will come out.
then during a 2nd gumball test, the knob and carousel will try to turn
a little left, then a little right, then stop, and I will get the
geneva switch error message....
in order to restart the gumball test, I reach in to remov the two
balls that are in the globe(the other four are in the carousel),
drop them into the out hole, and start the test again.
well,
it is now stuck doing the left/right jig, and popping up with the
geneva message, so this thing is jammed.....
OK, I have been around my machine quite a bit shopping it out,
replacing the main ramp, flipper assemblies, etc.....so can you just
give me a quick course in how much has to come off? I just want
to ensure I attack this thing properly.
My guess:
1. remove back board
2. remove triple tier of flasher lights in the back left corner of
pf
3. remove the red "flooring" surrounding cane-shaped wire ramp into
the gumball
4. remove the wire ramp into the gumball....
Am I close?
OK, I got it removed. I'll goof around with it to see what I can
see....
OK, Lloyd, I found it immediately!
I was wondering where one of my grey rubber switch covers I have on
the upper pf switches went to the other day!!!
It's inside the gumball, and apparently, lasted for several days before
getting in the wrong position......
pulled it out with tweezers.........
should I be able to manually turn the carousel manually? I hope not
as it won't budge, but I defintely removed the obstruction. I'll put
it back into a "temporary" mounting and give it a try....
OK, it's good to go!
Lloyd, I can't tell you how grateful I am for your help here. this NG
rocks!!
If you are ever in Columbus, OH, I'm buying you dinner...
thanks again.......
OK,
I have the entire back section removed. The four screws holding the
gumball to the top of the pf have been removed, All electrical
connectors under the bottom have been labled and pulled, so the
gumball is floating free, but won't pull through the top due to
hardware on the gumball under the pf that is wider than the opening.
so, at this point, what do I do to get the gumball removed? do I have
to remove the bottom section in order to get the top portion out?
nothing to panic about. Go into tests, go to gumball test, play with the
buttons until you get the empty gumball machine and empty it, see if it
works. If not check for loose connector for the motor to the motor board
below. If it seems stuck, take the top off, take the clear plastic divider
out, remove the balls and see if you can un jam it. LTG :)
<jjordan5@columbus.rr.com> wrote in message
news:1127521001.138127.198130@g44g2000cwa.googlegroups.com...
> Hi folks,
> thing.
> month ago..
> help, please......
You might have to dig deeper and see if anything is blocking the balls from
feeding down and out. It's a pretty simple and basic mechanism in there.
Did you take the top off, remove the clear plastic divider and remove the
balls ? LTG :)
news:1127521623.441289.206110@o13g2000cwo.googlegroups.com...
> Hi Lloyd,
That is because the gumball machine isn't turning. Ignore that message for
now, figure out first if the gumball machine is jammed with balls, or not
getting power to the motor. LTG :)
news:1127521715.502636.279730@f14g2000cwb.googlegroups.com...
> switch"......
Anything is possible. If it's trying to turn and can't, it's jammed. LTG :)
news:1127522344.140082.284770@z14g2000cwz.googlegroups.com...
> sorry,
You aren't a dope. You figured it out and posted to help others. Now is the
gumball machine working, ? If so, the geneva switch error will go away soon.
LTG :)
news:1127522458.403546.138470@g43g2000cwa.googlegroups.com...
First thing, from your other posts - forget the geneva error for now, that
is the switch at the bottom of the gumball machine and will turn up in error
if it isn't triggered by the moving mechanism, which isn't moving.
You don't need to remove the backboard. Long nut driver or grabber helps
here, remove the metal habitrail feeding into the rear of the gumball
machine, remove the plastic with flashers near the rear left, then remove
othe plastics around the gumball machine as needed. Then unplug the
connectors for the gumball machine undernetah the playfield, set playfield
back down, and remove the wood screws holding the gumball machine base to
the top of the playfield. Remove the gumball machine. Good time to look it
over and clean it inside and out. LTG :)
news:1127523878.786977.271420@g14g2000cwa.googlegroups.com...
> well,
> My guess:
> pf
> the gumball
> Am I close?
Glad you got through it, and thank you for following up with the fix. I
helped you, and now you'll help others when they search for help. And that
my friend helps everybody ! LTG :)
news:1127526605.802818.141130@g47g2000cwa.googlegroups.com...
> rocks!!
> thanks again.......
The gumball machine won't pull straight up. The motor/gearbox sticks back a
bit. Pull the gumball machine up slightly, tilt back, and wiggle forward.
Should come out easily. LTG :)
news:1127525393.373551.223070@o13g2000cwo.googlegroups.com...
> OK,
Congratulations...
A day I was wondering where a bulb finished. Where? Inside the GumBall!
The Alby87 Project
http://digilander.libero.it/alby1987/
