Hello,
I bought Skyrim off of Steam and I've been having the same problem as the OP. I tried changing the bFull Screen=1, and manually set the resolution but to no avail. Every time I start the launcher I uncheck 'windowed' mode (even though it automatically rechecks it each time I restart the launcher) and set the resolution to 1280 x 1024 (also resets itself to default every time game is closed). I have tried launching off Steam and off the TESV.exe file but it makes no difference.
I did a quick google search and I noticed that other people were having the same problem, but it was either: a) for a cracked version or b) fixed with a manual change to the 'bFull Screen=1' line in the skyrimprefs.ini file
I'm using:
Windows 7 64-bit
Latest version of steam/DirectX
AMD Radeon HD6800 Series
In the meantime, does anyone have any suggestions?
Thank you.
I'm using:
Windows 7 64-bit
Thank you.
