theme changing help/problem
nomis
Archived from groups: microsoft.public.windowsxp.customize (More info?)
okay for a start sorry if i have posted this in the wrong place but i was
unsure where it should go so i thought i put it here
right
my problem is that i used to use a program called window blinds on my
desktop pc, i recently uninstalled the program after selecting the classic
theme wicth i thought was a system preset. it now however seems that this is
not the case and now i have uninstalled the program i can't switch back to
the original windows xp theme, i can switch to themes that i have installed
after i recieved the system and before i installed windows blinds however i
can't switch to any system presets.
i was wondering if you guys could give me any help and a way to solve this
i have been looking around the help desk and found this article
http://support.microsoft.com/default.aspx?scid=kb;en-us;883391
however iam unsure as to weather this will work and do not wish to risk
anything untill i know that it is safe to do so
if it is any help windows blinds is part of object desktop witch is made by
stardock and a installer and more info can be found at
http://www.stardock.com/products/windowblinds/
thank you in advanced for your help with this matter
nomis
i would have asked this in a email but windows xp was pre installed when
recieved the system therfore i am not coverd for the 2 free help services and
at this moment in timeam unable to afford thye charges
Following the instructions in the MSKB article cannot do you any harm, as
you are putting in the normal defaults. Please try what it says, as it can't
leave you any worse off.
"nomis" <nomis@discussions.microsoft.com> wrote in message
news:7759E318-C994-448E-B3E4-8E13BBE8769B@microsoft.com...
> right
is
installed
i
by
> nomis
and
Hi,
Go to Start/Administrative Tools/Services/Themes. Set to Automatic.
Also check your settings here:
Start/Administrative Tools/Services/Terminal Services/Log On. At the bottom
ensure that Hardware Profile Original Configuration is Enabled.
If the above doesn't apply/nor help:
Only windows Classic is listed under Appearance:
1. Right click on the desktop and choose Properties.
2. On the Theme tab, choose the Windows XP.
3. If this option is missing, you may choose Browse... to
C:\Windows\Resources\Themes\Luna.theme
4. The Luna.theme is the theme of the Windows XP.
If Luna.theme is missing: Go to Start/Run/Msconfig/Expand Files:
Luna.MS_ and Luna.TH_
Restore Luna Theme (Line 187)
http://www.kellys-korner-xp.com/xp_tweaks.htm
Restore Themes Functionality (Line 187)
Troubleshooting Themes
http://www.kellys-korner-xp.com/xp_t.htm#themes
http://www.kellys-korner-xp.com/top10faqs.htm
Stuck in Classic View (Line 271)
In memory of our dear friend, MVP Alex Nichol: http://www.dts-l.org/
All the Best,
Kelly (MS-MVP)
Troubleshooting Windows XP
> right
> is
> installed
> i
> by
> nomis
> and
