Question Thermal Pad Thickness for ZOTAC RTX 3050 Twin Edge OC?
Mar 14, 2025
Hey everyone,
I have a ZOTAC GAMING GeForce RTX 3050 Twin Edge OC 8GB. I’m not experiencing any temperature issues, but since it’s been a little over two years, I’m considering replacing the thermal paste and pads.
Does anyone else have this exact GPU? I have no idea what thickness the thermal pads are, so I’d really appreciate any help!
Thanks in advance!
I would advise on tearing down the GPU yourself, to get to the thermal pads and then measuring them with a ruler or sliding caliper. You can then source something higher in quality like Fujipoly thermal pads or Thermal Grizzly and replace them. This way you familiarize yourself with the GPU and how to tear it down the next time around.
With that being said, the old adage of if it ain't broke don't fix it comes to mind after reading this line from you;
^ that's because the RTX 3050 is an entry level RTX card from the 3000 series, you're better off allocating better quality thermal pads on higher end cards.
Moved thread from Cooling section to Graphics Cards section.
Thanks a lot for your response! You’re absolutely right—I totally agree with the old saying, "If it ain't broke, don’t fix it." That’s exactly why I wanted to ask before tearing down my GPU. Why replace the thermal pads if I’m not having any issues?
The thing is, some technicians and YouTube tutorials recommend changing the thermal paste and thermal pads every year, which made me question whether it was really necessary. But since my temps are fine, I’ll hold off on taking it apart for now.
Again, I really appreciate your comment—it was super helpful!
They are full of crap, I've never had to replace pads or paste on my video cards.
Reactions: LuKaWin10
