4Ryan6
Champion
daglesj :
4Ryan6 :
All thermal compound is supposed to do, is fill the microscopic imperfections between the 2 contacting surfaces filling the microscopic air voids and that's it.
Replace the air with a good thermal conductor, to transmit the heat from one surface to the other, no thick layer!
A thick layer is bad!
The least used you can get away with the better the cooling performance, I don't care what brand it is.
What I've always done for years and works fine for me is once I've seated the HSF on the CPU and clamped it, I then unclamp and gently lift the HSF off.
This gives me a nice thin coating on both surfaces. The paste on the HSF is then cleaned off and I replace the HSF on the CPU with just the layer left on the CPU.
Basically this reduces the amount of paste by around 50% (give or take) but means I have a pretty thin even layer across both surfaces filling in those tiny tiny gaps.
Works a treat.
Did you test before and after temperature results?
