Third Hard drive problem.
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a 3rd hard drive connected to a USB2 board. It is broken into 2
partitions. I run xpsp2 prof. There is a directory which I cannot access or
delete. I cannot fdisk it either. How would I clean this out so that there
are no files in this partition so that I can reformat it?
"Bullwinkle. J. Moose" <moose.nyc@nospam.verizon.net> wrote in message
news:OnAraHGyEHA.2788@TK2MSFTNGP15.phx.gbl...
or
How did you "fdisk" your drive? There is no fdisk.exe under
WinXP - it's a Win9x command.
I would use the WinXP Storage Manager to delete all partitions
on the problem disk. You can then create new partitions and
format them.
Thanks. I found that out. I ended up by going to the windows xp resource kit
and used the disk management module to reformat the problem drive.
It worked. Thanks for your help.
"Pegasus (MVP)" <I.can@fly.com> wrote in message
news:O0hmalGyEHA.1396@tk2msftngp13.phx.gbl...
> or
>> there
> format them.
