Thoughts on my upcomming system
kersh
53
Hello
I have decided to make a new gaming system and would like to know if these parts will run together just fine.
Specs:
CPU: i5 3570K
Motherboard: Gigabyte GA-Z77X-UD3H
RAM: Corsair Vengeance Low Profile 8GB DDR3 1600MHz
Optical: Samsung SH-222BB DVD±RW
PSU: Corsair TX650W V2
Case: CM 690 II Advanced USB 3.0 version
SSD: Samsung 830 128GB
GPU: PowerColor HD7970 V2
I think these parts would work great together, if anyone got some thoughts about this please do tell.
Pretty decent setup, but have you considered a GTX 670? The 7970 is pretty cool, but I think the 670 is the current big dog on the video card block. (680s cost more and barely outperform 670s)
kersh
53
Yes, i wanted to go with the Asus DirectCU II GTX670 at first and these two cards are almost similar in pricing, here in Denmark, but i found a site in Germany that sells the PowerColor HD7970 V2 100$ cheaper than the price in Denmark, so i wanted to save some money and go with the Radeon since they perform basically the same.
the benches havent been updated for driver 12.7 yet. its more accurate to use toms 7970/ghz benches because it does use the 12.7 beta driver which almost universally increased the fps of radeon cards.
edit: or even overclockers clubs recent sapphire toxic 7970 ghz 6gb tests (it also does cards with similar powers as well), use the xfx black as sort of a reference for 7970s in general
Interesting. I believe you btw, like I said, there is no wrong answer with either of em, I say go with whichever is cheaper where the OP, although if the 7970 is cheaper, that works out pretty well for him. Although as far as drivers, I'd have to wonder what Nvidia could do with driver updates. My guess is they'll both huff and puff and realize its like Hercules fighting his clone from another dimension. Tell me I'm not the only nerd here who watched Hercules and Xena? :lol:
kersh
53
Thank you all for your input, i got one more question.
Do you think the Corsair TX 650W is enough if i want to OC the CPU and GPU later on? or should i perhaps switch to the 750W instead? i do not plan on running SLi.
N4villu5
11
If you plan on sticking with just one video card, the 650W should be enough.
kersh
53
Alright thanks!
