All links are either from PCPartPicker or Amazon since they are the most popular I usually see.
First build(work in progress, only have RTX 3060 Ti) so anything you want to advise into getting(within the same budget +-) I will take into consideration.
Already have Storage
Just have worries regarding the RGB fans, from what I gathered the mobo doesn't support ARGB directly. My question is, will this hub/controller included in the pack allow me to address the LEDs/speed(From both the 3 fans purchases and 3 ARGB from the case), if yes, where should I connect it to?
Thank you for your help!
CPU | Ryzen 5 3600X | 212€( 3€ more than normal 3600) |
GPU | MSI RTX 3060 Ti | 425€ |
MOBO | MSI B450M MORTAR MAX | 84€ |
RAM | GSkill Aegis 16GB(2X8GB) 3200MHz | 69€ |
CASE | Phanteks P400A RGB | 89€ |
PSU | Kolink Enclave 700W FM 80+Gold | 79€ |
EXTRA FANS | Aerocool Astro Pro 12 + Hub + Controller | 30€ |
