[SOLVED] Time to upgrade parts. Advice for things what i should take to account?
Nico_13
5
Hi,
I need advice when making upgrades to my current gear. What should i take into account when making changes for example more powerful GPU & CPU. Could you give me suggestions?
My current gear:
Mother:
GA-Z170-GAMING K3-EU, LGA1151, Intel Z170, DDR4,
CPU
Skylake i5-6600K, LGA1151, 3,5GHz, 6MB, Tray
GPU
Palit GeForce GTX 1060 Dual, 6GB GDDR5
CPU Cooler
Noctua NH-D9L (LGA 115x/2011, AMD AMx
Power supply
650W, VS650, ATX
Memory
Kingston 8GB(2x4GB) HyperX Fury DDR4 2666 MHz, CL15
SSD Disk
250GB 850 EVO SSD SATA III, 540/520 M
What I´m planning
-RTX 2080
-i9 9900k
-(already bought new motherboard Z390-F Rog Strix)
-(already bought memory from 8 GB --> 16 GB )
Should i update my power supply & CPU cooler when i buy i9 & RTX2080?
Something else i should take into account?
I appreciate your advice in advance thank you!
You should upgrade the PSU, the VS series are very poor as far as quality and the 9900K/ RTX 2080 draws much more power then your current system.
I would suggest a good quality 750W unit such as the Seasonic Focus Gold.
what wildcard said.
No way I would let a VS power a new "gaming" rig.
So you bought a new set of 2x4 GB 2666 mhz of the same ram?
G.SKill Flare X DDR4 RAM 16 GB
  • 2x 8 GB DIMM, 2400 MHz
  • CL15 timing, 1.2/1.35 V
  • Designed for AMD Ryzen
This is what i bought. I sold my old ones.
Thank you so much. I did look into that model and it seems pretty decent price and its pretty available in my country. Great!
