Hi, so before I get into the tale of diagnosis attempts the specs of the build are/were:
i5 8600k cooled by a be quiet shadow rock LP
GTX 1070
8GB DDR4
Asrock Z370M-ITX/AC
Samsung 850 EVO+ Western digital HDDs
EVGA 650G
Last year I moved house, it turned out to be damp. I left for the weekend came back to turn it on and was greeted by a puff of smoke from my power supply which at the time was a CX600m. I replaced it with a EVGA 650G, this works. Now that I'm back from uni I tested it in an old pc. My GPU displays from this old pc and my storage is detected by it (WOOO!!!). The last few days I've been playing around with different possibilities. Just trying to boot as is results in hard drives powering on, all system fans spinning. I do not have any beep codes or LEDs coming from the board. Following this it turns off after around 20 seconds. If I remove the CPU, the fans stay on. But obviously no boot and no error codes. I don't have access to a compatible CPU or a motherboard with the same socket type to test.
Does anyone have any diagnosis suggestions or experience with a similar situation? Or any way of determining if it's the motherboard or CPU or both?
I want to repair this for relatively cheaply student and the current world situation encourages frugality. So I'm weighing up buying a second hand 8400 or 8600k. Trying it and then replacing the board if it's also dead. Or getting a Ryzen 5 2600/3600 and a B550 board which will end up costing the same if I replaced both.
Thanks for your help.
A guy who misses playing Sid Meier's Railroads more than he should do.
GTX 1070
8GB DDR4
Asrock Z370M-ITX/AC
EVGA 650G
