When I built my last system back in 2008 various blogs said that I should wet-sand and polish the top surface of my CPU and the bottom surface of my heatsink to flatten and maximize the surface areas for best heat transfer. This I did to my Noctua NH-12 cooler using a piece of plate glass and a succession of sandpaper grits up to 6,000 if memory serves correctly. I declined to do this to my quad core CPU lest I get metal dust in the pins, but the system worked perfectly and has run very cool to this day.
I'm now building a replacement for that system using an Intel i5-13600K CPU and an updated Noctua NH-U12A cooler designed to fit the new LGA1700 ASUS Z790 Plus motherboard.
I've not heard much on the need to polish CPUs and coolers since 2008. Does this mean that polishing is no longer required? I should think that polishing would be more important with today's more power hungry chips than in the past.
Your thoughts?
Your thoughts?
