[SOLVED] Top Mounted AIO in Cooler Master TD500 Mesh
surendhiran977
6
I'm planning to use the CORSAIR iCUE H150i RGB PRO XT 360mm AIO in a TD500 Mesh case from Cooler Master. I only want to mount the AIO at the top.
Will that be possible? I saw their website, saw a bunch of videos. But I'm not completely sure.
Have any of you done that?
Thanks for your time!
You'd be best off having the AIO in the front and set the fans to intake air through the mesh for the best temps on your CPU. This build seems to have done what you want to do, thought it look a little tight up there.
Latest posts
