Question tower pc case suggestions if i have 120 mm fans, 240mm radiator, and If i want 40cm GPU clearance for at least a 4080, and enough clrnce for RM1000x
Znn
Commendable
Aug 30, 2022
82
13
1,545
(i currently own a prebuilt, with some upgraded parts..., but i want to switch cases to fit a 4080 since my current case won't fit. my current case fits 3070)
does anyone have any tower pc case suggestions with filters, if i have already have 2 front intake 120 mm fans (about 2.5 cm thick) with 240mm radiator (around 2.7 thick, I think) that is currently attached behind the 2 fans , 1 exhaust 120 mm fan at the back of case, and If i want at least 37-40cm GPU clearance for a 4080? also some space for RM1000x psu
my specs
Cpu: Oem Intel Core Processor I7-12700kf 8p/16 + 4e 3.60ghz 25mb Cache [w/o Graphic] 125w Lga1700
Cpu Cooler: Cyberpowerpc Deepcool Castle 240ex Argb Aio Liquid Cpu Cooler W/ Anti-leak Technology
And Deepcool Castle Aio Liquid Cpu Cooler Retention Kit (lga1700 & Lga115x)
Fans : Cyberpowerpc Dual Addressable Digital Argb 120mm Fan 3pins
Ram: G.skill Trident Z Rgb Series 32gb (2 X 16gb) 288-pin Sdram Pc4-28800 Ddr4 3600 Cl18-22-22-42 1.35v
Ssd: 1tb Wd Blue Sn570 Pcie Nvme M.2 Ssd & Samsung 970 Evo Plus 1tb Nvme M.2 Internal Ssd
Gpu: planning to get some type of 4080, max dimension of 4080s I think are around 33.8 x 12.7 x 5.5 cm
Os: Windows 11 Home Advanced Digital License
Case: Cyberpowerpc Amethyst Ii 241v Mid W/ Tempered Glass (black) 3 X Argb Fan Retail
Psu: upgraded to RM 1000x corsair
Motherboard: Asus Prime Z690-p Wifi Ddr4 Atx Wi-fi 6 2.5gbe Lan 4 Pcie X16 1pcie X1 3x M.2 Sata/pcie Lga1700 Cec
Essentially any full-tower ATX PC case will do (super-tower ATX as well, if you want to go big). But since choosing a PC case is personal choice, take your pick;
pcpp: https://pcpartpicker.com/products/case/#t=4&sort=price&page=1
Once you've found what you like, might want to check clearances from official specs (e.g GPU clearance), just in case.
E.g i'm personally using full-tower ATX Corsair Graphite 760T V2 Black,
specs: https://www.corsair.com/eu/en/Categories/Products/Cases/Graphite-Series™-760T-Full-Tower-Windowed-Case/p/CC-9011073-WW
And all your components fit into it just fine + ample space is left over.
Same goes for full-tower ATX Corsair Obsidian 750D AirFlow Edition, where my missus'es PC lives in,
specs: https://www.corsair.com/us/en/p/pc-...low-edition-full-tower-atx-case-cc-9011078-ww
If you want to see how hardware sits in them, check out my Skylake and Haswell builds from my signature (plenty of pics).
E.g both PC cases have 45cm for GPU, 17cm for CPU cooler, support 120/140mm fans all around + other neat aspects.
Reactions: Znn
This is all going to depend on what you like appearance wise and how much money you are willing to spend.
There are lots of those massive cases with the front and side all glass. You can also get many other more simple cases for well under $100.
I suspect we will soon start seeing the "best of 2023" articles and videos. Many times they have lists of cases.
In the end it is going to be what do you like the best. Only you can say if a case that is painted bright red might be the one for you. Just make sure there is lots of mesh panels so air can get in and out of the case
Reactions: Znn
Awesome, thx!
Reactions: Aeacus
