Question Tp-link AC1750 Archer c7 problems
Mar 21, 2020
Hello everybody, hope you all well, i want to get advice since tp link support and forum have huge delay, so here it goes:
I have a cable modem (200mpbs), and i just bought tplink archer c7, i've installed it as the instructions say, on the first 24 hours after i buy it, the speed was LOW, but not extremely slow, we suffer from disconnection every 5 hours, but now it's getting worse, the speed is extremely slow (5mpbs to each pc) and the connection is lost 2 times an hour (disconnected), i have 3 pc connected and 1 phone wireless.
The configuration in the router is:
Nat + nat boost is enabled.
Firmware is up to date.
Qos disabled.
Cables cat 5e (is ok).
What I've done so far:
1 - Reset.
2 - Disable nat + nat boost.
3 - Enable and disable QoS.
The problems are:
1 - The router keeps disconnected 2 times in an hour.
2 - The speed is extremely slow.
3 - Sometimes the router haves like "peaks" speeds, and sudden the speed is 80mpbs but after 10 minutes the speed decreasing to 5mpbs.
I would love to solve it instead of waiting the entire year to tplink support, thanks.
Qos disabled.
1 - Reset.
The problems are:
Many cable modems have status displays you can access by typing 192.168.100.1 into a browser -- https://www.howtogeek.com/240575/ho...ms-diagnostic-page-when-something-goes-wrong/ . Try that.
Make sure your signals to your cable modem are good. It could be your in-house wiring is not providing good connectivity to your modem.
What do the LEDs on the modem and router do when you have a disconnect ?
All the icons are green, except the "world" icon going orange.
I think the signals are ok since the previous router works well, but he was limit to 100mpbs so i had to upgrade.
What model is the modem? I would HIGHLY recommend you look at the data. Just saying that "the old one worked" is no guarantee that the new one is happy. A new modem has new requirements.
The modem is from our cable company, i will look for the model, for now, i follow the link above, and i see too many details what i don't understand them...sorry....but there is menus: "basic", "advanced", "wireless", "mta".
I came across this under "stauts > connection":
Acquire Downstream Channel219000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
Configuration FileOK
SecurityEnabledBPI+
SecurityEnabledBPI+
Read the link I posted about interpreting the data. The important things are the power level downstream (should be around 0db) -3 to plus 6 are good. And signal to noise ratio. Around 40db or higher is better. Here is another how-to page -- https://pickmymodem.com/signal-levels-docsis-3-03-1-cable-modem/
I think this is:
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
Downstream Bonded Channels
1 QAM256 219000000 Hz 2.1 dBmV38.1 dB00
2 QAM256 177000000 Hz 3.3 dBmV39.1 dB00
3 QAM256 183000000 Hz 3.0 dBmV39.3 dB00
4 QAM256 189000000 Hz 2.8 dBmV38.9 dB00
5 QAM256 195000000 Hz 2.0 dBmV38.5 dB00
6 QAM256 201000000 Hz 2.1 dBmV38.3 dB00
7 QAM256 207000000 Hz 3.1 dBmV38.6 dB00
8 QAM256 213000000 Hz 2.6 dBmV37.9 dB00
I think this is:
1QAM256219000000 Hz2.1 dBmV38.1 dB00
2QAM256177000000 Hz3.3 dBmV39.1 dB00
3QAM256183000000 Hz3.0 dBmV39.3 dB00
4QAM256189000000 Hz2.8 dBmV38.9 dB00
5QAM256195000000 Hz2.0 dBmV38.5 dB00
6QAM256201000000 Hz2.1 dBmV38.3 dB00
7QAM256207000000 Hz3.1 dBmV38.6 dB00
8QAM256213000000 Hz2.6 dBmV37.9 dB00
Yes. those look like decent values. The next thing to check is the log the modem has. When the "world" turns orange, that usually means that the modem has lost connection to the ISP.
Reactions: King_V
There was now a disconnected, i go to the modem log:
Sun Mar 22 01:52:04 2020 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=.......;CMTS-MAC=.....-QOS=1.1;CM-VER=3.0;
Sun Mar 22 01:51:16 2020 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=.......;CMTS-MAC=........*;CM-QOS=1.1;CM-VER=3.0;
Sun Mar 22 01:51:16 2020 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=........;CMTS-MAC=......;CM-QOS=1.1;CM-VER=3.0;
The internet come back again after 5 minutes, but with slow connection, i've try to log in to the modem but it give a message:
"wan connection error! unable to connect to the internet please contact your service provideror try again later"
any ideas?
Update: again extremly slow connection.
the modem level is the same.
The support from tp-link advised to turn the router to access point, i will give it a try, if not they give the option to get new.
Still a problem, the RMA can't replace in this time because of the corona virus.
I will try to convert it to access point, i will google and update.
