transferring files using RJ45 cable
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
I read through most of the other posts, but coundn't find the answer.
Just bought a new computer which uses XP. My old computer uses XP as well,
although I believe its a different version. I went to a computer store, and
they told me I could use a RJ45 cable (looks like an ethernet cable to me) to
transfer my files and settings.
I used the wizard, but it doesn't work. Keeps asking for serial cables and
such. I tried using the network wizard to connect the two, but that didn't
work either.
Can someone please help me??
Thanks for everyones help with the cable issue. I have learned about cables
and that all makes sense.
However, I still can't get the transfer wizard, or the networking wizard to
work. The 2 computers never recognize each other. I know this should be
easier than it is, and I'm sure I'm doing something wrong. But I've followed
those wizard instructions perfectly.
Should I just be focusing on the networking wizard to transfer?
> work either.
"yellowesc6" <yellowesc6@discussions.microsoft.com> wrote in message
news😀7ABCCE2-9DA1-4DE5-88A0-50A4A6FC4EB3@microsoft.com...
> and
> to
> work either.
Is the cable you got a crossover cable, if it's not, it won't work. To tell
what one should look like hold the 2 RJ45 connectors next to one another and
if they look like they are wired exactly the same, then it's not a crossover
cable.
I looked at the cable, and you're correct. They look exactly the same. Guess
its back to the store for another cable.
Thank you for your help!
> > and
> > to
> > work either.
> cable.
One more question...so I apologize for this. I thought I understood and I
don't.
I'm not sure what wired the same means? When I look at the wires inside
them, it appears the colors of the wires in the 2 ends go to different places
in each. Does that mean they are wired differently?
> > and
> > to
> > work either.
> cable.
Usually a crossover cable is labeled as such, because it can't be used in a
LAN under normal circumstances. Read the cable markings. It should tell you.
Regards,
Richard Urban
Microsoft MVP Windows Shell/User
Quote from: George Ankner
"If you knew as much as you thought you know,
You would realize that you don't know what you thought you knew!"
news:BC17D39F-8BE8-4545-9379-32E6F4F5B661@microsoft.com...
> don't.
> places
>> > well,
>> > and
>> > me)
>> > to
>> > and
>> > didn't
>> > work either.
>> tell
>> and
>> crossover
>> cable.
> and I don't.
> inside them, it appears the colors of the wires in the 2 ends go to
> different places in each. Does that mean they are wired differently?
Hold both connectors up, side by side. Make sure they are both facing up
(or down) the same. I think it is easier to look at the bottom sides,
the side without the little clamp thingy (tech term ;-) ). You'll see
these wires: red/white, red, green/white, green/white, green, blue,
orange/white, orange. If both ends, held the same way, show the same
colors of wires in the same order, then you have straight-through cat5e
cable. You use this to connect to a router, hub, or switch. If you are
trying to connect two computers directly to each other, you need
cross-over cat5e cable and the colored wires will be in a different
order on each end.
HTH,
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
The cable is labeled CAT 6 Crossover.
> Regards,
> Richard Urban
> > don't.
> > places
> >> > well,
> >> > and
> >> > me)
> >> > to
> >> > and
> >> > didn't
> >> > work either.
> >> tell
> >> and
> >> crossover
> >> cable.
Then you're good to go.
Regards,
Richard Urban
news:2D6DCB01-3C5C-4BFD-BADB-50E33ED6C907@microsoft.com...
>> a
>> you.
>> Regards,
>> Richard Urban
>> > I
>> > don't.
>> > places
>> >> > well,
>> >> > store,
>> >> > and
>> >> > to
>> >> > me)
>> >> > to
>> >> > cables
>> >> > and
>> >> > didn't
>> >> > work either.
>> >> To
>> >> tell
>> >> another
>> >> and
>> >> crossover
>> >> cable.
Crossover cable looks like this:
http://www.cisco.com/warp/public/135/bbsm_lvl2spprt3.gif
> don't.
> places
>> > well,
>> > and
>> > me)
>> > to
>> > and
>> > didn't
>> > work either.
>> tell
>> and
>> crossover
>> cable.
Regular cat5 network cable will have the same wiring on both ends
"Johnny Lingo" <johnnylingo@spammenot.com> wrote in message
news:EY6Te.88173$084.65943@attbi_s22...
>> don't.
>> places
>>> > well,
>>> > store,
>>> > and
>>> > me)
>>> > to
>>> > and
>>> > didn't
>>> > work either.
>>> tell
>>> and
>>> crossover
>>> cable.
news:CE567ED2-C8F1-4BB1-9273-89817C1648FF@microsoft.com...
> cables
> to
> followed
>> well,
>> and
>> me) to
>> and
>> didn't
>> work either.
As you appear to have the correct cable, make sure both pc's are in the same
workgroup.
