![qQLouI3.png](https://i.imgur.com/qQLouI3.png)
Troubleshooting and diagnosing graphics card issues
It's an extremely common problem seen throughout tech forums. You've installed a new graphics card and immediately experience either severe gaming performance issues, crashes when booting into windows or other display related problems that seem to be directly related to the new card.
Some problems are more complicated than others, but as a basic reference for solving the most common issues I suggest taking the following steps to ensure the problem is not something simple that can be easily cured.
The first thing to do is make certain your power supply is not the issue.
One of the most common mistakes made by those looking to upgrade system components, especially graphics cards, is thinking that they can use their current OEM or cheap off brand unit because "somebody else" did it without encountering a catastrophe. There is a very common misconception which has been appropriately addressed countless times by experienced users, builders and contributors to tech forums worldwide for years.
Picking The Right Power Supply: What You Should Know
Just because your PSU has a label saying it's 600w and you KNOW you only need 550w, does NOT mean you are ok with that unit after upgrading to a gaming or enthusiast graphics card. Mainstream systems or those with integrated graphics, in the manner of the Intel iGPU on their i-series chips, or AMD's APUs, use much less continuous power than that which is demanded by aftermarket PCIe high end graphics cards.
Knowing that leads us to the well documented fact that there are a heck of a lot of power supplies out there, even units sold by big names like Corsair, Cooler Master and Thermaltake, that can't provide their listed capacity. More often that not, when the unit says, for example, 600w, it's actual sustained capacity is much less. It might not even be capable of peaking anywhere near that.
Don't be surprised when your cheap PSU blows up
![](https://i.imgur.com/5Q3dLNS.jpg)
If you are upgrading to a high end GPU solution you are well served by also confirming you have a high quality, exceptionally reliable power supply to eliminate the potential for complications or even hardware failures. Using a model listed below as recommended, while not an exhaustive list of every model out there worth using, will at least serve to help you avoid getting a poor quality or underpowered unit.
![](https://i.imgur.com/BpO1yw6.jpg)
Power supply recommendations
Let's start with the biggest misconception out there, which is that if a unit has high watts it will be ok or is good. No. Just, no.
There are plenty of 750-1000w units out there that I wouldn't trust to power a light bulb and might in fact be more dangerous due to their supposedly high capacity due to poor or non-existent protections inside the unit.
If the platform isn't good to begin with, how many watts or amps it says it can support is irrelevant.
Higher 80plus certification doesn't mean anything, UNLESS it's on an already known to be high quality PSU platform. For example, a Seasonic Prime platinum unit is going to be a better product than a Seasonic Prime Gold unit, because we already know the Prime platform is very good, and platinum efficiency along with it shows there are some improvements internally to account for the higher efficiency.
In a case like that, it might be worth it. It's likely the unit will create less heat, it will probably have better performance in regard to ripple, noise and voltage regulation. It might shave a few pennies, or dollars, off the electric bill over the course of a year.
Other than that, it is not going to perform any better than the same platform with Gold efficiency. On the other hand, just because a unit has Titanium 80plus ratings doesn't mean the unit is any good at all. For example, there are Raidmax units with Titanium efficiency and I wouldn't trust one of those to power a light bulb. There are a lot of units like this out there.
If the platform isn't good to begin with, whether or not it has an 80plus certification or not is irrelevant.
The recommendations at the following link in terms of the recommended capacity for the entire system based on the model of the graphics card are a good basic guideline to use when choosing from the models below if you need or desire a replacement power supply.
RealHardTechX PSU capacity recommendations by card model
Whatever you do, don't EVER buy a power supply based on whether it has RGB or lighting, or looks like it might be a quality unit. Some of the biggest hunks of junk out there look just as good as a Seasonic Prime Ultra Titanium, but I assure you, they are not. So far as I've seen there are really no excellent units out there that have RGB built in. Maybe one or two models, but rest assured you'll be be paying for the lighting, not for the quality of the power supply.
I don't know what country you reside in, and I know that sometimes it's hard to come by good units in some regions, but when possible, when it comes time to get that PSU, I'd stick to the following if you can.
Seasonic. Seasonic isn't just a brand, they are a PSU manufacturer, unlike many of the PSU brands you see they make their own power supply platforms AND a great many of the very good PSU models out there from other brands like Antec, Corsair and older XFX are made by Seasonic.
Just about anything made by Seasonic is good quality for the most part. There are really no bad Seasonic units and only a very few that are even somewhat mediocre. They do make a few less-good quality OEM style units, but mostly those are not going to be units you come across at most vendors, and they are still not bad. Also, the S12II and M12II 520 and 620w units are older, group regulated models. At one time they were among the best units you could buy. Now, they are outdated and not as good as almost any other Seasonic models. They are however still better than a LOT of newer designs by other manufacturers.
The Seasonic 520w and 620w S12II/M12II units CAN be used on newer Intel platforms, if you turn off C6/C7 in the bios, but I'd really recommend a newer platform whenever possible. Prices are usually pretty good on those though, so sometimes it's worth accepting the lack of DC-DC on the internal platform. Higher capacity versions of the High current gamer are not based on that platform, so they are fine. Those being the 750w and higher versions.
Most common currently, in order of preference, would be the Seasonic Focus series, then Focus plus, then Prime, then Prime ultra. It's worth mentioning that there are generally Gold, Platinum and Titanium versions within each, or most, of those series, but that does not necessarily mean that a Focus plus Platinum is necessarily better than a Prime Gold. It only means that it scored better in the 80plus efficiency testing, not that the platform is better.
Again, don't let yourself get tangled up in the idea that a higher 80plus rating specifically means that it is a better unit than another one with a lower rating, unless you know that it is a good platform from the start. All these Focus and Prime units are pretty good so you can somewhat focus on the 80plus rating when deciding which of them to choose.
Super Flower Super Flower is another PSU manufacturer. They also make most of the good units sold by EVGA like the G2, G3, P2 and T2 models.
Super Flower doesn't have a very broad availability for the units with their own brand name on them, and are not available in a lot of countries but for those where there is availability you want to look at the Leadex and Leadex II models. The Golden green platform is fairly decent too but is getting rather long in the tooth as a platform AND I've seen some reviews indicating a few shortcomings on units based on this platform.
Even so, it's a great deal better than a lot of other platforms out there so you could certainly do worse than a Golden green model. Units based on the Leadex and Leadex II platforms are much better though.
Corsair. The CX and CXm units are ok as a budget option, but I do not recommend pairing them with gaming cards. The newer 2017 models of CX and CXm are better than the older ones, but still not what we'd call terrific, so if it specifically says 2017 model, or it has a capacity other than an even 100, like 550w, 650w, 750w, etc., then it's likely at least better than those older ones. Aside from that, any of the TX, RMx, RMi, HX, HXi, AX or AXi units are good. Those are listed from best to worst, with the best being the AX and AXi units.
Antec. The True power classic units are made by Seasonic, and are very good, but are not modular. The High current gamer 520w and 620w, or any other PSU you see on the market that is 520w or 620w, are also made by Seasonic, based on the S12II and M12II platform for modern versions, and are pretty good units but again they are an older platform that is group regulated so if you go with a Haswell or newer Intel configuration you will want to avoid those because they do not support the C6/C7 Intel low power states.
The Antec High current gamer 750w and 850w units are very good and are not the older design, which came in 520w and 620w capacities and were good for back then but again, are an aging Seasonic platform that is not the best choice most of the time these days. Occasionally, these older units MIGHT be the best unit available and you could do worse than one of them, but a newer DC-DC platform is desirable when possible if it doesn't mean sacrificing quality elsewhere in the platform. There are however older and newer HCG models, so exact model number will likely be a factor if choosing one of these however both the older models and the newer models are good.
Antec Edge units are ok too, but reviews indicate that they have noisy fan profiles. I'd only choose this model if it is on sale or the aesthetics match up with your color scheme or design. Still a good power supply but maybe a little aggressive on the fan profile. This may have been cured on newer Edge models so reading professional tear down reviews is still the best idea.
Antec Earthwatts Gold units are very good also.
BeQuiet. BeQuiet does have a few decent models, BUT, you must be VERY selective about which of their models you put your trust in. From model to model their are huge differences in both quality and performance, even with the same series. If you cannot find a review for a BeQuiet unit on HardOCP, JonnyGuru or Tom's hardware that SPECIFICALLY says it is a very good unit, and does not have any significant issues in the "cons" category, I would avoid it. In fact, I'd probably avoid it anyhow unless there is a very great sale on one that has good reviews, because their units are generally more expensive than MUCH better units from Antec, Seasonic, EVGA and Corsair.
Super Flower. They are like Seasonic and they make power supplies for a variety of other companies, like EVGA. Super Flower units are usually pretty good. I'd stick to the Leadex, Leadex II and Golden Green models.
EVGA. They have BOTH good and not very good models.
Not very good are the W1, N1, B1, B3 (All models except the 650w model), BQ, BR, BT and G1 NEX models.
Good models are the B2, B3 650w, G2, G2L, G3, GQ, P2 and T2 models.
FSP. They used to be very mediocre, and are a PSU manufacturer like Seasonic and Super Flower, although not as well trusted based on historical performance. Currently the FSP Hydro G and Hydro X units are pretty good.
I would avoid Thermaltake and Cooler Master. They do have a few good units, but most of the models they sell are either poor or mediocre, and the ones they have that ARE good are usually way overpriced.
This is just ONE example of why I say that. Very new and modern CM unit. One of the worst scores ever seen on JonnyGuru for a well known brand name product. Doesn't look to be much better than a Raidmax unit. Sad.
Cooler Master Masterwatt Lite 600W review
And most of the models I have linked to the reviews of at the following link are at least good, with most of them being fantastic.
Power supply discussion thread
Certainly there ARE some good units out there that you won't see above among those I've listed, but they are few and far between, much as a hidden nugget of gold you find in a crevice among otherwise ordinary rocks and don't EVER assume a unit is good just because of the brand.
If you cannot find an IN DEPTH, REPUTABLE review on Tom's hardware, JonnyGuru, HardOCP, Hardware secrets (Old reviews by Gabe Torres), Kitguru (Only Aris reviews), TechPowerUP, SilentPC crew or a similar site that does much more than simply a review of the unboxing and basic tests that don't include reliable results for ripple, noise, voltage regulation and a complete teardown of the unit including identification of the internal platform, then the unit is a big fat question mark.
I recommend not trusting such units as companies generally always send out review samples of any unit they feel is going to get a good review, and don't send them out if they know they are going to get hammered by the reviewer. No review usually equals poor quality. Usually.
Other models that should never be trusted OR USED AT ALL, under any circumstances, include A-Top, AK Power, Alpine, Apevia, Apex (Supercase/Allied), Artic, Ace, Aerocool (There might be one model worth using, but I'd still avoid them.), Aspire (Turbocase), Atadc, Atrix, Broadway com corp, Chieftech, Circle, CIT, Coolmax, Deer, Diablotek, Dynapower, Dynex, Eagletech, Enlight, Eurotech, Evo labs, EZ cool, Feedtek, Foxconn, G7, HEC/Compucase Orion, HEDY, High power, iBall, iStar computer co., Jeantec, JPac, Just PC, Kolink, LC Power, Linkworld electronics, Logisys, Macron, MSI, NmediaPC, Norwood Micro (CompUSA), Okia, Powercool, Powmax, Pulsepower, Q-tec, Raidmax, RaveRocketfish, Segotep, SFC, Sharkoon, Shuttle, Skyhawk, Spire, Startech, Storm, Sumvision, Tesla, Trust, Ultra, Wintech, Winpower, Xilence (Until I see a reputable review of a model showing different), xTreme (Cyberpower), Youngbear and Zebronics.
Driver installation
The next big issue for many users is having a CLEAN driver installation. Many users upgrading from older cards or integrated graphics that use older driver versions by the same OEM, meaning Nvidia or AMD based, often assume it will be a bang, bang process. Sometimes it is if they've kept up with keeping the drivers current but more often it is not.
It's also often not enough to simply install the drivers that came on disk with the graphics card or to just find and download current drivers. In many cases the system has seen repeated driver updates, partial or damaged driver installations or the installation of differently tiered graphics products in addition to a variety of different "tweaking" utilities, all of which may have left behind varying levels of registry entries and system file versions that are likely to cause complications with the installation or implementation of new drivers.
This can have a wide variety of results including no problems at all, refusal of the new drivers to even install or anything in between as well as driver conflicts and poor performance. It's imperative that you start with a clean slate by removing ALL previous graphics drivers for that architecture or platform that might interfere with the transition to the new drivers. Making sure you are trying to install drivers INTENDED for use with your GPU model or Windows version is extremely important as well.
There has been a high level of success resolving these kinds of issues by doing the following.
Click here for FULL instructions on how to do a CLEAN install of your graphics card driver using the Display Driver Uninstaller (DDU)
You will want to prepare for that by downloading any of the following that are relevant to your configuration.
Nvidia graphics drivers
![](https://i.imgur.com/8pwO9mS.png)
AMD graphics drivers
![](https://i.imgur.com/x9VazJo.jpg)
Download and run Wagnard tools "Display driver uninstaller" which I highly recommend and is fully endorsed by many top level tech websites including Guru 3D and Tom's Hardware. Choose the option from the drop box that applies to your platform, AMD, Nvidia or Intel, and when it asks to reboot into safe mode in order to perform the uninstall process, click yes and allow the program to proceed.
Guru3D Display Driver Uninstaller
![](https://i.imgur.com/06BgpQZ.png)
After the uninstallation process is complete, install the new driver package you previously downloaded followed by a reboot of the system to ensure the new drivers are properly initiated.
Using the DDU to create a clean environment is sufficient for a large majority of users but is not going to be the immaculate solution for every user and every situation. Some issues are more involved and may require a new Windows installation or further investigation to determine hardware and other driver compatibility.
It's also a good idea on AMD systems to make sure the chipset drivers are up to date which can be found here:
*AMD Chipset drivers
If your issue is still unresolved or was not driver related to begin with, there are a few other things to check.
Double checking to see that the GPU card is FULLY seated in the PCIe slot, and that it's actually in the correct slot for single or multi GPU configuration to begin with according to the specifications outlined in your motherboard's manual is a good place to begin. Reseating graphics cards often solves the issue immediately. When using dual card configurations, sometimes swapping places with the cards will resolve failure to Crossfire or SLI, or even be detected.
Be sure to check that the "lock" on the end of the PCIe slot is in the open position before attempting to install the card and that once fully seated, the lock is now engaged.
Make absolutely certain you have any and all necessary supplementary power cables connected to the graphics card and that the cables are firmly seated on both ends, especially on modular power supplies as they can often seem seated on the PSU socket but in reality are not fully bottomed into the socket.
Check to see that you did not forget to move the VGA, HDMI, DVI or Displayport cable from the motherboard's integrated display output to the appropriate port on your graphics card.
If you are using a power strip, discard it and plug directly into the wall socket using the power cable from your PSU. Power strips are notoriously cheap and problematic, often causing voltage issues with the demand of the new card despite having a capable power supply.
If none of these solutions resolves your issue or you have issues unrelated to these solutions, feel free to contact myself or other members with the link to your thread and in most cases we'll be happy to do our best to help you solve your issue. Remember, this is just a basic troubleshooting guide for the layman, more complicated issues with compatibility and performance may require additional or entirely disparate remedies.
