G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati,microsoft.public.windowsxp.hardware,microsoft.public.windowsxp.video,alt.os.windows-xp,comp.sys.ibm.pc.hardware.video (More info?)
I have an ATI Radeon 9800 Pro which has been having problems with the
TV-Out capability. ATI has been less than helpful in trying to help
me resolve them. The issue is the quality of the picture is very
poor. Before anyone interjects and says TV-Out quality is normally
poor, I am aware of that, but it is even worse than it should be.
Specifically what I am seeing is as follows: While the PC boots the
TV-Out quality is as expected. I can clearly see my POST and early
boot-up sequence. The Windows XP splash screen looks perfect, than
right when the scrolling progress indicator on the splash screen
pauses (mine always pauses for a split second after being up for a few
seconds.) the picture becomes very snowy. Shortly thereafter the
picture goes away entirely. Now this happens whether I have any ATI
specific driver loaded or not. (That is to say, even with no ATI or
Windows drivers for the 9800 Pro loaded, I get TV-Out up to this
point.) If I do have the latest 9800 Pro drivers loaded, I must
enable TV-Out from the driver control panel, however the quality is
still very poor as mentioned above. I had a 9700 Pro in the past
which seemed to work fine (except it would overheat so ATI sent me a
new 9800 Pro replacement)
Additionally, after messing around with it for a while, I decided to
re-install Windows from scratch. Everything worked perfectly for a
few weeks (including TV-
Out) but then just today, the problem came back. There is nothing I
can put my finger on in terms of software I have installed, or driver
updates I may have gotten to cause the issue. I have obviously
re-installed all the video drivers to no avail. I have also
un-installed anything I could think of since It last worked. No dice.
Tried restoring to a restore point where I know it worked, still no
help.
If anyone knows of any issues, has seen this problem before, or has
any info on how I can proceed, I would appreciate it very much. I am
a software engineer, so no need to dumb it down for me.
I am currently running SP2 with all the latest updates. However as
mentioned before, I have not updated Windows in the recent past so it
did work with SP2 installed previously.
john
Splendid
Aug 25, 2003
3,819
Just an idea:
Check the frequency. on the back of the tv it will say 120 volt, 60hz ,
make sure the frequency is set the same on the computer.
The reson it may be clear while booting is the system uses the bios
defaults, then widows takes control once its booted
control panel>display>settings>advanced>monitor
"Dan K" <joeblow65@mail.com> wrote in message
news:166e7679.0411071802.18e0a4c6@posting.google.com...
> help.
G
Guest
Guest
Thanks John, but the 9800 Pro (and most newer video cards) have a
seperate DAC for the TV-Out (S-video) connector, which is forced to
60Hz, regardless of the frequency of the VGA output. Besides if the
frequency weren't matched there would be an even more pronounced
problem such as scrolling and tearing of the image, not just a snowy
image.
Thanks for the idea though, glad to see some good feedback.
Dan K.
"JOhn" <barnesj@shaw.ca> wrote in message news:<loBjd.143740$nl.137676@pd7tw3no>...
> Just an idea:
> > help.
G
Guest
Guest
Quick update...
It appears the problem is caused by my Sound Blaster Audigy. It turns
out if I disable the digital audio output on the Audigy (which by the
way is connected to the same amplifier that receives the S-Video
input) the problem goes away. Of course now I don't have sound!
(Simply disconnecting the RCA cable accomplishes the same as turning
it off in the driver.) The reason it worked for a while was because I
just recently reconnected the digital audio output after re-installing
Windows. (It had been connected for over a year with my 9700 Pro and
worked fine.) Therefore it is my conclusion that there was a hardware
redesign between the ATI Radeon 9700 Pro and the Radeon 9800 Pro which
made the S-Video output more susceptable to interference. Now why the
Audigy card is causing this interference is another good question. I
doubt neither Creative Labs, nor ATI will take any responsibility for
this issue.
My next step will be to attempt to connect everything into the same
outlet (computer, monitor, amp, tv, etc.) to prevent any ground loop
possibilities and see what happens.
Later,
Dan K.
joeblow65@mail.com (Dan K) wrote in message news:<166e7679.0411101320.36fb5999@posting.google.com>...
> image.
> Dan K.
> > Just an idea:
> > > help.
G
Guest
Guest
ATI cards ARE COMPLETE AND UTTER SHITE (and they know it)
AVOID THEM!(rip off merchants)
stick to nvidia (a superior product)
z
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware,microsoft.public.windowsxp.video (More info?)
Well thank you trippy123 for that in depth analysis....Now do you know
anything about NVidia's Geforce 3 ti200 blanking or placing my Packard Bell
Model 2020 into standby mode when I activate "The Incredibles" action game
for PC Users??
> z
G
Guest
Guest
You get all kinds around here, don't you? That GeForce card is a bit on the
old side, isn't it? Are you sure it has the horsepower to handle a game
like The Incredibles? You may have to turn all the cool effects off to
lessen the burden on the card. As an aside, I haven't seen a Packard Bell
system in years. They were run out of the US some time ago for selling new
computers with used parts in them and neglecting to tell anyone about it.
"DamonB" <DamonB@discussions.microsoft.com> wrote in message
news:76057538-B373-40DB-AA4A-C4406CFB34E8@microsoft.com...
> Bell
> for PC Users??
>> z
G
Guest
Guest
You may be right about horsepower....I found that the game works correctly in
480x640 mode, but in 800x600 or 1024x768 it causes the PB2020 to go into
standby. As for the monitor, I've had that baby since 1992...12 years and
still looks good. I think I need to take a closer look at the refresh
settings in 800x600 (set for 60hz) especially since XP actually runs in that
mode....and the game doesn't. Any guesses on why??
> > Bell
> > for PC Users??
> >> z
G
Guest
Guest
Could it be that you may have to dial up the refresh rate for the game to be
drawn properly by your card? Try 75hz and see what happens in 800 x 600.
news:A293758E-28AB-456B-A783-D553F5FFAFE4@microsoft.com...
> in
> that
>> the
>> Bell
>> new
>> > Bell
>> > game
>> > for PC Users??
>> >> z
