I dropped my water bottle on the floor and it kind of splashed upwards all over my table including very little water droplets on the bottom of my screen while it was asleep.
I wiped off water with microfiber cloth from the bottom of my screen as fast as I could and I don't see anymore water, I turned on the laptop screen and it's working fine, no dead pixels or any distortion.
Are there generally any other safety measures I should take or is this ok?
If any water did get UNDER themonitor screen, albeit I bet it was VERY little, will this clear out by itself overtime and if not is it okay to leave it? Would I even notice it's effects later on?
For reference just enough water was here to be seen and wiped off: https://prnt.sc/1uk7owi
