I have a Corsair Carbide Spec-01 case which comes with a single fan pre-installed. I use an MSI H110M PRO VH-PLUS motherboard, which has a four pin slot for the fan. From what I learned by searching online, it should connect just fine but I've tried everything to fit the cable into the slot, but it just won't go in. I'm currently running the system without any case fan. Is there anything I can do to fix this? Maybe through some sort of converter? Is it safe to keep running the system without the fan?
Thank you.
Thank you.
