Upgrade WinXP Home Sp2 to WinXp Pro
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics,microsoft.public.windowsxp.general (More info?)
Can someone direct me to the KB or other help on
upgrading XP Home to XP Pro when Home has XP2
installed.
I don't have a FULL Pro XP 2, just the Full SP1 and
the upgrade SP2 so when I try to "upgrade" with SP1
it complains of a lesser version (since Home is already
at SP2.)
I suppose my options include:
1) Uninstalling SP2 before the upgrade
2) Slipstreaming an installation point of XP Pro to SP2
Are there simple options for doing this?
Herb Martin
Herb;
Those are the correct and simple options.
Unless you want to perform a Clean Installation of Windows XP Pro then
install SP-2.
Jupiter Jones [MVP]
http://www3.telus.net/dandemar/
"Herb Martin" <news@LearnQuick.com> wrote in message
news:%23SdIAWn3EHA.1400@TK2MSFTNGP11.phx.gbl...
> installed.
> at SP2.)
> Herb Martin
> installed.
> at SP2.)
http://www.theeldergeek.com/slipstreamed_xpsp2_cd.htm
"Jupiter Jones [MVP]" <jones_jupiter@hotnomail.com> wrote in message
news:OPacOio3EHA.1452@TK2MSFTNGP11.phx.gbl...
> Herb;
> install SP-2.
Thanks to all respondents.
I found the required upgrade disk (I believe) so that skips
some steps.
So I now have a (real) WinXP w/ SP2 CDROM and will
try that later today.
Thanks again.
Herb Martin
> Jupiter Jones [MVP]
> > installed.
> > at SP2.)
> > Herb Martin
Start/Control Panel/Add or Remove Programs/scroll down towards the
bottom and find "Windows XP Service Pack 2"/click it to highlight
it/click "Remove'. After removal completes, install your upgrade to XP
Pro/then re-install Service Pack 2/then go to the Windows Update site.
Fool around with slipstreaming AFTER you get Prof up and running. Then
use it the next time you have to re-install XP [that time always comes].
Gene K
> installed.
> at SP2.)
