Upgrading GPU Problem
BarBruh
Commendable
Nov 17, 2016
Hello people,
So I'm in the middle of looking for a suitable GPU for my PC as my other one kind of died. So I have a pre-built pc that I brought a while ago with these specs
MotherBoard- Foxconn 2ADA
CPU-i7 3770
Ram- 8GB
GPU-GT 640 (Broken that's why I need to replace it)
PSU-300W
Full PC here- http://h20564.www2.hp.com/hpsc/doc/p...r_na-c03743724
So I am looking at 2 cards that I would like to buy and I saw that they should be alright but I want to make sure my self with my PC. I am looking at either the
ASUS Nvidia GeForce GTX750 Ti OC 2GB
or
ASUS Nvidia GeForce GTX750 OC 1GB
So I was wondering if either of them will be able to run in my PC.
Thanks guys
Yes but I suggest either the 1050 or 1050ti. They are way faster than the old 750 and only $109 and $139. The 1050 is as fast as the GTX960 and the 1050ti beat it a good deal.
Video Card: MSI GeForce GTX 1050 2GB Video Card ($109.99 @ B&H)
Total: $109.99
Generated by PCPartPicker 2016-11-17 10:44 EST-0500
or
Video Card: EVGA GeForce GTX 1050 Ti 4GB SC GAMING ACX 2.0 Video Card ($129.99 @ Newegg)
Total: $129.99
Generated by PCPartPicker 2016-11-17 10:45 EST-0500
Thanks for the prompt reply, however I'm planning on purchasing these from a store Today and don't really have time to wait for delivery, and as I'm planning on building a PC sometime next year around March time and I will have a much higher budget then, but as you've said these will work fine and I only need them for a little while.
Thanks
Your link does not work, it goes to a logon screen.
Without changing your psu,
GTX1050 or GTX1050ti is the strongest card you can use.
GTX750ti or GTX750 is a bit weaker, but will still be a nice jump over your GT640.
Just make certain that you do not pick a heavily overclocked card that needs a 6 pin connector.
Your new card must run on pcie x16 slot power only.
