Upgrading - need some insight on my chosen build
Felyth
Hello there! So basically I've decided to upgrade my pc . I'm gonna use the pc mostly for "gaming" (hate that word) .At the moment I want to set the cpu's clock rate to 4.5 GHz hoping that my cpu cooler can handle it and for the future I would maybe like to add a 2nd 1070 and an SSD (M.2) for the games.
This is what I've come up with so far https://pcpartpicker.com/user/Felyth/saved/mrnVnQ
Would really appreciate some insight.
I have marked the components that I am planning to keep with *
My current build is :
- CPU - i5-2500k (Sandy Bridge)
- CPU cooler - Cooler Master Hyper 412S*
- Motherboard : asus p8p67-M
- RAM : 4x 4GB DDR3 Corsair Vengeance
- HDD: WD-Blue 3TB 5400RPM*
- SSD: Intel - 535 Series 120gb * (using it for my OS and other programs - no games)*
- GPU: MSI GeForce GTX 970 4GB
- PSU: a 5-6 year old Corsair GS700
- Case: Corsair 780T ATX Full Tower Case *
Hi,
Everything looks fine from a compatibility standpoint. Not sure which games you are playing and at what resolution but you might want to downgrade your CPU and upgrade your GPU. The big issue is what resolution.
http://www.tomshardware.com/answers/id-3380642/7600k-gtx-1080-7700k-gtx-1070.html
Also, your PSU was not correct in the build, you had the RM750i while you state that you have the GS700. Here is the i5-7600K/GTX 1080 build.
PCPartPicker part list: https://pcpartpicker.com/list/B42Zd6
Price breakdown by merchant: https://pcpartpicker.com/list/B42Zd6/by_merchant/
CPU: Intel - Core i5-7600K 3.8GHz Quad-Core Processor ($228.66 @ OutletPC)
CPU Cooler: Cooler Master - Hyper 412S 52.6 CFM CPU Cooler (Purchased For $0.00)
Motherboard: MSI - Z270 GAMING M5 ATX LGA1151 Motherboard ($169.99 @ Amazon)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory ($122.99 @ Best Buy)
Storage: Intel - 535 Series 120GB 2.5" Solid State Drive (Purchased For $0.00)
Storage: Western Digital - Blue 3TB 3.5" 5400RPM Internal Hard Drive (Purchased For $0.00)
Video Card: Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card ($509.99 @ Amazon)
Case: Corsair - 780T ATX Full Tower Case (Purchased For $0.00)
Power Supply: Corsair - Gaming 700W 80+ Bronze Certified ATX Power Supply (Purchased For $0.00)
Operating System: Microsoft - Windows 10 Pro OEM 64-bit ($133.49 @ SuperBiiz)
Total: $1165.12
Generated by PCPartPicker 2017-05-08 06:43 EDT-0400
i think u can use r windows as its a hardware upgrade. so :
CPU: Intel - Core i7-7700K 4.2GHz Quad-Core Processor ($336.88 @ OutletPC)
Motherboard: ASRock - Z270 Killer SLI/ac ATX LGA1151 Motherboard ($143.98 @ Newegg)
Memory: Team - T-Force / Night Hawk 16GB (2 x 8GB) DDR4-3000 Memory ($104.99 @ Newegg)
Total: $1095.84
Generated by PCPartPicker 2017-05-08 07:10 EDT-0400
